Gstreamer audio latency
I’m trying the below pipeline as follows:
gst-launch-1.0 -v alsasrc device=plughw:2,0 buffer-time=7000 ! volume volume=8 ! opusenc bitrate-type=vbr bitrate=160000 hard-resync=true ! oggmux max-delay=0 ! tcpclientsink host=localhost port=9055
The above pipeline works fine on an NPM server. Unfortunately, the pipeline has a latency of 2s to reach the browser.
Is there any other method to mitigate this latency?
Thanks in advance !
Please try UDP and see if the latency is less. There is a discussion about video streaming through TCP:
Gstreamer TCPserversink 2-3 seconds latency
There is improvement in UDP. It may be same for audio. Please give it a try.
Definitely, i will try and let you know.
