Thread 22 “nvv4l2h264enc0:” received signal SIGTRAP, Trace/breakpoint trap.
[Switching to Thread 0x7f58a311c0 (LWP 14158)]
raise (sig=5) at …/sysdeps/unix/sysv/linux/raise.c:51
51 …/sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) bt #0 0x0000007fb747f2f0 in raise (sig=5) at …/sysdeps/unix/sysv/linux/raise.c:51 #1 0x0000007fb73b4be0 in g_logv () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0 #2 0x0000007fb73b4de4 in g_log () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0 #3 0x0000007fb72da8d8 in gst_structure_set () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0 #4 0x0000007fa80e9d3c in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so #5 0x0000007fb7189688 in gst_video_encoder_finish_frame () at /usr/lib/aarch64-linux-gnu/libgstvideo-1.0.so.0 #6 0x0000007fa80ebbb0 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so #7 0x0000007fb72e7eb4 in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0 #8 0x0000007fb746b000 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
(gdb)
my gstreamer pipeline works the first time I use it, I get the CRITICAL after removing splitmuxsink and dynamically adding it back.
So I added GST_DEBUG=3 to see if I could get some information and got CRITICAL about the debug on the initial run of my gstreamer pipeline.
How is a customer suppose to debug a system CRITICAL that does not give any information?
Is the nvarguscamerasrc source code available for debugging, and the source code for the nvarguscamerasrc libraries?
using leporard imaging imx334 with their driver in R32.1, waiting on leporard imaging for 32.2.1, hopefully nvarguscamerasrc and it’s library is updated.
Thread 1 “VideoSystem.not” received signal SIGTRAP, Trace/breakpoint trap.
(gdb) bt #0 0x0000007fb747f2f0 in raise (sig=5) at …/sysdeps/unix/sysv/linux/raise.c:51 #1 0x0000007fb73b4be0 in g_logv () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0 #2 0x0000007fb73b4de4 in g_log () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0#3 0x0000007fb729eaac in gst_debug_log_valist () at /usr/lib/aarch64-linux-gnu/ #4 0x0000007fb729ebac in gst_debug_log () at /usr/lib/aarch64-linux-gnu/libgstr #5 0x0000007fa80dc4a8 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgst #6 0x0000007fa80dcc78 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgst #7 0x0000007fa80e40c8 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgst #8 0x0000007fa80ec080 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgst #9 0x0000007fb71871b4 in () at /usr/lib/aarch64-linux-gnu/libgstvideo-1.0.so.0 #10 0x0000000000000002 in ()
(gdb)
