s.n.3
December 6, 2024, 3:46am
1
When I tried the following pipeline with the attached video files,
the following assertion occurred.
How can I avoid this ?
In case of 8192 x 2169 video file, it’s no problem.
gst-launch-1.0 filesrc location=/home/sp2/Media/ColorBar_hevc_8192_1648_60.mp4 ! decodebin ! nvvidconv output-buffers=20 ! “video/x-raw(memory:NVMM), format=RGBA” ! nv3dsink
Setting pipeline to PAUSED …
Pipeline is PREROLLING …
Opening in BLOCKING MODE
(gst-launch-1.0:16755): GStreamer-CRITICAL **: 12:07:10.182: gst_caps_is_empty: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:16755): GStreamer-CRITICAL **: 12:07:10.182: gst_caps_truncate: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:16755): GStreamer-CRITICAL **: 12:07:10.182: gst_caps_fixate: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:16755): GStreamer-CRITICAL **: 12:07:10.182: gst_caps_get_structure: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:16755): GStreamer-CRITICAL **: 12:07:10.182: gst_structure_get_string: assertion ‘structure != NULL’ failed
(gst-launch-1.0:16755): GStreamer-CRITICAL **: 12:07:10.182: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
NvMMLiteOpen : Block : BlockType = 279
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 279
Allocating new output: 8192x1648 (x 13), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 8192, nFrameHeight = 1648
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:03.281589152
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
The maximum resolution is 8K 7680x4320 and the width 8192 exceeds the capability. It may not work properly since the resolution is over-spec.
For capability of Xavier NX module, please check
Jetson Download Center | NVIDIA Developer
s.n.3
December 9, 2024, 12:58am
4
One more question about the maximum resolution.
Is is possible to support (width, height) = (4320, 7680) video ?
4320x7680 is not validated so it may not work properly. Height 7680 may hit certain constraint in hardware decoder.
s.n.3
December 9, 2024, 2:34am
6
My question is about hardware decoder.
As long as I checked decoding 4360x7680, assertion didn’t occur.
Thanks for the correction. I have modified it to decoder.
We don’t validate it. You may try more video files and see if all are good.
system
Closed
December 31, 2024, 7:16am
9
