gst_mini_object_set_qdata: assertion ‘object != NULL’
I am seeing this CRITICAL error and then our application hangs when running under nvidia-docker2 on JP4.5.
Our image is based off of:
FROM nvcr.io/nvidia/deepstream-l4t:5.1-21.02-base
The container is run like this:
docker run --privileged --rm --net=host --ipc=host -e DISPLAY=$DISPLAY -v /tmp/argus_socket:/tmp/argus_socket --cap-add SYS_PTRACE -v ~/.Xauthority:/root/.Xauthority -v /tmp/.X11-unix/:/tmp/.X11-unix --device /dev/video0 --device /dev/video1 myimage:latest
$ cat /etc/docker/daemon.json
"default-runtime": "nvidia",
"runtimes": {
"nvidia": {
"path": "nvidia-container-runtime",
"runtimeArgs": []
Witthout docker, I am able to start and stop pipelines normally. But within docker I see the critical failure above and hang.
What am I doing wrong?
