GStreamer Error Jetpack 4.5 Dusty-Nv imagenet.py
Hey I want to check if this is a JP 4.5 issue before I flash back to 4.4 as suggested elsewhere. I was attempting to run imagenet on a classification model I quickly re-trained but even though I am feeding it images and not using camera, it fails to load because there is no camera…
error:
  error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:645 No cameras available
  [gstreamer] gstCamera -- end of stream (EOS)
(python3:10585): GStreamer-CRITICAL **: 14:39:08.784: gst_mini_object_set_qdata: assertion 'object != NULL' failed
Output of ls -l /dev/video*:
nvidia@nvidia-desktop:~$ ls -l /dev/video*
ls: cannot access '/dev/video*': No such file or directory
v41-utils was installed via sudo apt-get.
My command:
python3 imagenet.py --model=test_001.onnx --labels=testlabels.txt --input_blob=input_0 --output_blob=output_0 --input_URI=test_images/*.jpg --output_URI=test_results/result_%i.jpg
Hi @tom.parkerete4t, which camera are you using?
If it’s a MIPI CSI camera, are you able to see the image stream with nvgstcapture-1.0?
I am not using a camera, none plugged in, I am giving it images as input.
I just ran nvgstcapture and this was the output, same problem (this time I plugged in my webcam which has worked with jetson before, just to test it, it is a C220)
Output:
nvgstcapture-1.0
Encoder null, cannot set bitrate!
Encoder Profile = High
Supported resolutions in case of ARGUS Camera
  (2) : 640x480
  (3) : 1280x720
  (4) : 1920x1080
  (5) : 2104x1560
  (6) : 2592x1944
  (7) : 2616x1472
  (8) : 3840x2160
  (9) : 3896x2192
  (10): 4208x3120
  (11): 5632x3168
  (12): 5632x4224
Runtime ARGUS Camera Commands:
  Help : 'h'
  Quit : 'q'
  Set Capture Mode:
      mo:<val>
          (1): image
          (2): video
  Get Capture Mode:
      gmo
  Set sensor orientation:
      so:<val>
          (0): none
          (1): Rotate counter-clockwise 90 degrees
          (2): Rotate 180 degrees
          (3): Rotate clockwise 90 degrees
  Get sensor orientation:
      gso
  Set sensor mode:
      smo:<val> e.g., smo:1
  Get sensor mode:
      gsmo
  Set Whitebalance Mode:
      wb:<val>
          (0): off
          (1): auto
          (2): incandescent
          (3): fluorescent
          (4): warm-fluorescent
          (5): daylight
          (6): cloudy-daylight
          (7): twilight
          (8): shade
          (9): manual
  Get Whitebalance Mode:
      gwb
  Set Saturation (0 to 2):
      st:<val> e.g., st:1.25
  Get Saturation:
      gst
  Set Exposure Compensation (-2 to 2):
      ec:<val> e.g., ec:-2
  Get Exposure Compensation:
      gec
  Set Auto Whitebalance Lock:
      awbl:<val> e.g., awbl:0
  Get Auto Whitebalance Lock:
      awbl
  Set Auto Exposure Lock:
      ael:<val> e.g., ael:0
  Get Auto Exposure Lock:
      gael
  Set TNR Mode:
      tnrm:<val> e.g., tnrm:1
          (0): OFF
          (1): FAST
          (2): HIGH QUALITY
  Get TNR Mode:
      gtnrm
  Set TNR Strength (-1 to 1):
      tnrs:<val> e.g., tnrs:0.5
  Get TNR Strength:
      gtnrs
  Set EE Mode:
      eem:<val> e.g., eem:1
          (0): OFF
          (1): FAST
          (2): HIGH QUALITY
  Get EE Mode:
      geem
  Set EE Strength (-1 to 1):
      ees:<val> e.g., ees:0.5
  Get EE Strength:
      gees
  Set Auto Exposure Anti-Banding (0 to 3):
      aeab:<val> e.g., aeab:2
          (0): OFF
          (1): MODE AUTO
          (2): MODE 50HZ
          (3): MODE 60HZ
  Get Auto Exposure Anti-Banding:
      gaeab
  Set Gain Range:
      gr:<val><space><val> e.g., gr:1 16
  Get Gain Range:
      ggr
  Set Exposure Time Range:
      etr:<val><space><val> e.g., etr:34000 35000
  Get Exposure Time Range:
      getr
  Set ISP Digital Gain Range:
      dgr:<val><space><val> e.g., dgr:2 152
  Get ISP Digital Gain Range:
      gdgr
  Capture: enter 'j' OR
           followed by a timer (e.g., jx5000, capture after 5 seconds) OR
           followed by multishot count (e.g., j:6, capture 6 images)
           timer/multihot values are optional, capture defaults to single shot with timer=0s
  Start Recording : enter '1'
  Stop Recording  : enter '0'
  Video snapshot  : enter '2' (While recording video)
  Get Preview Resolution:
      gpcr
  Get Image Capture Resolution:
      gicr
  Get Video Capture Resolution:
      gvcr
Runtime encoder configuration options:
  Set Encoding Bit-rate(in bytes):
      br:<val> e.g., br:4000000
  Get Encoding Bit-rate(in bytes):
      gbr
  Set Encoding Profile(only for H.264):
      ep:<val> e.g., ep:1
          (0): Baseline
          (1): Main
          (2): High
  Get Encoding Profile(only for H.264):
      gep
  Force IDR Frame on video Encoder(only for H.264):
      Enter 'f'
bitrate = 4000000
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
Opening in BLOCKING MODE
** Message: 15:13:42.730: <main:4670> iterating capture loop ....
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:645 No cameras available
(nvgstcapture-1.0:14648): GStreamer-CRITICAL **: 15:13:42.877: gst_mini_object_set_qdata: assertion 'object != NULL' failed
Oh, I see, sorry I misunderstood I thought you were trying to use camera. Can you try running it like this:
python3 imagenet.py --model=test_001.onnx --labels=testlabels.txt --input_blob=input_0 --output_blob=output_0 "test_images/*.jpg" test_results/result_%i.jpg
woot! thank ye!
