Jetson Info:
Software part of jetson-stats 4.2.12 - (c) 2024, Raffaello Bonghi
Model: Jetson AGX Orin - Jetpack 5.1.1 [L4T 35.3.1]
NV Power Mode[0]: MAXN
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
- Module: Check with sudo
Platform:
- Distribution: Ubuntu 20.04 focal
- Release: 5.10.104-tegra
jtop:
- Version: 4.2.12
- Service: Active
Libraries:
- CUDA: 11.4.315
- cuDNN: 8.6.0.166
- TensorRT: 8.5.2.2
- VPI: 2.2.7
- Vulkan: 1.3.204
- OpenCV: 4.10.0 - with CUDA: YES
I try theese code to start rtsp server with gmsl camera:
import gi
gi.require_version('Gst', '1.0')
gi.require_version('GstRtspServer', '1.0')
from gi.repository import Gst, GstRtspServer, GObject
class RTSPServer:
def __init__(self):
# 初始化 GStreamer
Gst.init(None)
# 創建 RTSP 伺服器
self.server = GstRtspServer.RTSPServer()
# 設定 RTSP 伺服器端口
self.server.set_service("8554")
# 建立媒體工廠,並設置 GStreamer 管道
factory = GstRtspServer.RTSPMediaFactory()
factory.set_launch((
"v4l2src device=/dev/video0 ! "
"videoscale ! "
"nvvideoconvert ! "
"x264enc ! "
"h264parse ! "
"rtph264pay name=pay0 pt=96"
factory.set_shared(True) # 允許多個客戶端共享
# 將工廠掛載到 RTSP 伺服器的 "/mystream" 路徑
self.server.get_mount_points().add_factory("/mystream", factory)
def start(self):
# 啟動 RTSP 伺服器
self.server.attach(None)
print("RTSP server is running at rtsp://127.0.0.1:8554/mystream")
GObject.MainLoop().run()
# 啟動 RTSP 伺服器
if __name__ == "__main__":
server = RTSPServer()
server.start()
But I use VLC Player use rtsp to play,
like theese error:
ubuntu@EAC-5000:~/workspaces$ python3 '/home/ubuntu/workspaces/deep_stream_view/DeepStream-gi/deepstream_gi_mu
lti_display_rtsp.py'
/home/ubuntu/workspaces/deep_stream_view/DeepStream-gi/deepstream_gi_multi_display_rtsp.py:36: PyGIDeprecationWarning: GObject.MainLoop is deprecated; use GLib.MainLoop instead
x264 [error]: baseline profile doesn't support 4:2:2
And I try install ffmpeg
sudo apt install ffmpeg
But still can’t find avenc_h264
element:
ubuntu@EAC-5000:~/workspaces$ gst-inspect-1.0 avenc_h264
No such element or plugin 'avenc_h264'
How can I install?
Thanks!!!
