This issue seems to be associated with only certain cameras. The same gstreamer pipeline works fine with other camera. As far as we can see we could access the stream using ffplay command. The gstreamer command,
gst-launch-1.0 uridecodebin uri='rtsp://admin:admin%40123@172.16.16.227:554/streaming/channels/101' ! nvvideoconvert ! videorate ! 'video/x-raw, framerate=30/1' ! nveglglessink sync=false
Is this a known issue or is there a fix around it? Deepstream doesn’t start on these streams.
DaneLLL
February 13, 2020, 9:02am
2
Please try to render through nvoverlaysink and see if it works:
gst-launch-1.0 uridecodebin uri='rtsp://admin:admin%40123@172.16.16.227:554/streaming/channels/101' ! nvoverlaysink
And run export GST_DEBUG=FACTORY :4 to print what elements are picked by uridecodebin.
DaneLLL
February 20, 2020, 8:48am
4
Please share log with export GST_DEBUG=FACTORY :4
kayccc
March 3, 2020, 7:06am
5
Hi beefshepherd,
Have you managed to get issue resolved? Any result can be shared?
