What’s the bug filing channel?
I have noticed an issue where gstreamer with omxh265enc, control-rate 2 and 4k would hang at encoding.
Changing either the control-rate to 0 or encoding 2k seems to be fine.
I believe this is a bug, any channel I can file this bug?
You can submit bugs here: https://developer.nvidia.com/nvidia_bug/add
Best,
Tom
We do not see any issue in running below pipelie:
nvidia@tegra-ubuntu:~$ gst-launch-1.0 videotestsrc num-buffers=300 is-live=true ! video/x-raw,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),width=3840,height=2160,format=NV12' ! omxh265enc control-rate=2 ! fakesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 8
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
Got EOS from element "pipeline0".
Execution ended after 0:00:09.996654691
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Can you check if something wrong in your pipeline? Are you on r31.1/DS3.0 or r28.2.1/DS1.5?
