I need to design a function which need to add and remove different net cameras by delete and new gstreamer pipeline.
And I found that when decoder destructor, the memory about 20~80M can not be release until the program is killed.
So I wonder if I forget to release something else, i did not know.
Decoder::Decoder(string url)
pthread_mutex_init(&mutex_, NULL);
/* Initialize GStreamer */
gst_init(NULL, NULL);
string launch_string;
launch_string = "rtspsrc location=" + url + " ! rtph264depay ! ";
launch_string += "h264parse ! omxh264dec ! ";
launch_string += "appsink name=mysink";
GError *error = NULL;
pipeline_ = (GstPipeline *)gst_parse_launch(launch_string.c_str(), &error);
if (pipeline_ == NULL) {
g_print("Failed to parse launch: %s\n", error->message);
return;
appsink_ = (GstElement *)gst_bin_get_by_name(GST_BIN(pipeline_), "mysink");
g_object_set(appsink_, "emit-signals", TRUE, NULL);
g_signal_connect(appsink_, "new-sample", G_CALLBACK(new_buffer_fcn), this);
/* Instruct the bus to emit signals for each received message, and connect to the interesting signals */
GstBus *bus = NULL;
bus = gst_pipeline_get_bus(pipeline_);
gst_bus_add_signal_watch(bus);
g_signal_connect(G_OBJECT(bus), "message::error", (GCallback)error_cb, main_loop_);
gst_object_unref(bus);
/* Start playing the pipeline */
gst_element_set_state((GstElement *)pipeline_, GST_STATE_PLAYING);
/* Create a GLib Main Loop and set it to run */
main_loop_ = g_main_loop_new(NULL, FALSE);
pthread_create(&thread_, NULL, main_loop_fcn, main_loop_);
return;
Decoder::~Decoder()
gst_element_set_state((GstElement*)pipeline_, GST_STATE_NULL);
gst_object_unref(GST_OBJECT(pipeline_));
gst_object_unref(GST_OBJECT(appsink_));
g_main_loop_quit(main_loop_);
g_main_loop_unref(main_loop_);
pthread_mutex_destroy(&mutex_);
