Hello, we connect IP Camera to TX2 with 100M Ethernet, the network cable length is around 100 meters. And we forward IP Camera RTSP stream to another Ethernet port on carrier board, then view the RTSP stream with vlc player on one laptop which connect to that Ethernet port.
However, the RTSP stream playing will stop within one hour, the vlc debug log is as below,
main debug: processing request item: rtsp://192.168.100.152:5060/live.sdp, node: 播放清單, skip: 0
main debug: rebuilding array of current - root 播放清單
main debug: rebuild done - 3 items, index 2
main debug: starting playback of new item
main debug: resyncing on rtsp://192.168.100.152:5060/live.sdp
main debug: rtsp://192.168.100.152:5060/live.sdp is at 2
main debug: creating new input thread
main debug: Creating an input for 'rtsp://192.168.100.152:5060/live.sdp'
main debug: requesting art for new input thread
main debug: using timeshift granularity of 50 MiB
main debug: using timeshift path: C:\Users\AIM050~1\AppData\Local\Temp
main debug: `rtsp://192.168.100.152:5060/live.sdp' gives access `rtsp' demux `any' path `192.168.100.152:5060/live.sdp'
main debug: creating demux: access='rtsp' demux='any' location='192.168.100.152:5060/live.sdp' file='\192.168.100.152:5060\live.sdp'
main debug: looking for access_demux module matching "rtsp": 15 candidates
live555 debug: version 2016.11.28
main debug: looking for meta fetcher module matching "any": 1 candidates
lua debug: Trying Lua scripts in C:\Users\aim050048\AppData\Roaming\vlc\lua\meta\fetcher
lua debug: Trying Lua scripts in C:\Program Files (x86)\VideoLAN\VLC\lua\meta\fetcher
main debug: no meta fetcher modules matched
main debug: looking for art finder module matching "any": 2 candidates
lua debug: Trying Lua scripts in C:\Users\aim050048\AppData\Roaming\vlc\lua\meta\art
lua debug: Trying Lua scripts in C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art
lua debug: Trying Lua playlist script C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\00_musicbrainz.luac
lua debug: skipping script (unmatched scope) C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\00_musicbrainz.luac
lua debug: Trying Lua playlist script C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\01_googleimage.luac
lua debug: skipping script (unmatched scope) C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\01_googleimage.luac
lua debug: Trying Lua playlist script C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac
lua debug: skipping script (unmatched scope) C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac
lua debug: Trying Lua playlist script C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\03_lastfm.luac
lua debug: skipping script (unmatched scope) C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\03_lastfm.luac
main debug: no art finder modules matched
live555 debug: authentication failed
live555 debug: retrying with user=root
qt debug: IM: Setting an input
live555 debug: RTP subsession 'video/H264'
main debug: selecting program id=0
live555 debug: setup start: 0.000000 stop:0.000000
live555 debug: We have a timeout of 70 seconds
live555 debug: play start: 0.000000 stop:0.000000
main debug: using access_demux module "live555"
main debug: looking for packetizer module matching "any": 25 candidates
h264 debug: found NAL_SPS (sps_id=0)
h264 debug: found NAL_PPS (pps_id=0 sps_id=0)
main debug: using packetizer module "h264"
main debug: looking for video decoder module matching "any": 19 candidates
avcodec debug: using ffmpeg Lavc58.6.103
avcodec debug: CPU flags: 0x000fd3db
avcodec debug: allowing 5 thread(s) for decoding
avcodec debug: codec (h264) started
avcodec debug: using frame thread mode with 5 threads
main debug: using video decoder module "avcodec"
main debug: looking for meta reader module matching "any": 2 candidates
lua debug: Trying Lua scripts in C:\Users\aim050048\AppData\Roaming\vlc\lua\meta\reader
lua debug: Trying Lua scripts in C:\Program Files (x86)\VideoLAN\VLC\lua\meta\reader
lua debug: Trying Lua playlist script C:\Program Files (x86)\VideoLAN\VLC\lua\meta\reader\filename.luac
main debug: no meta reader modules matched
main debug: `rtsp://192.168.100.152:5060/live.sdp' successfully opened
live555 warning: no data received in 10s. Switching to TCP
main debug: killing decoder fourcc `h264'
main debug: removing module "avcodec"
main debug: removing module "h264"
main debug: Program doesn't contain anymore ES
live555 debug: tk->rtpSource->hasBeenSynchronizedUsingRTCP()
main debug: Buffering 0%
main debug: Buffering 2%
main debug: restarting module due to input format change
avcodec debug: available hardware decoder output format 119 (cuda)
avcodec debug: available hardware decoder output format 53 (dxva2_vld)
avcodec debug: available hardware decoder output format 118 (d3d11va_vld)
avcodec debug: available hardware decoder output format 174 (d3d11)
avcodec debug: available software decoder output format 12 (yuvj420p)
avcodec debug: trying format d3d11va_vld
main debug: Buffering 5%
main debug: looking for text renderer module matching "any": 3 candidates
freetype debug: Using DWrite backend
freetype debug: DWrite_GetFamily(): family name: Arial
freetype debug: DWrite_ParseFamily(): using font at index 0 with weight 400 for bold: 0, italic: 0
freetype debug: DWrite_ParseFamily(): using font at index 1 with weight 700 for bold: 1, italic: 0
freetype debug: DWrite_ParseFamily(): using font at index 2 with weight 400 for bold: 0, italic: 1
freetype debug: DWrite_ParseFamily(): using font at index 3 with weight 700 for bold: 1, italic: 1
main debug: using text renderer module "freetype"
main debug: looking for video converter module matching "any": 24 candidates
swscale debug: 32x32 (32x32) chroma: YUVA -> 16x16 (16x16) chroma: RGBA with scaling using Bicubic (good quality)
main debug: using video converter module "swscale"
main debug: Buffering 28%
yuvp debug: YUVP to YUVA converter
main debug: using video converter module "yuvp"
main debug: Deinterlacing available
main debug: deinterlace -1, mode auto, is_needed 0
main debug: looking for vout window module matching "qt,any": 3 candidates
qt debug: requesting video window...
main debug: resized to 600x343
main debug: Buffering 31%
main debug: resized to 1920x904
main debug: resized to 1920x1080
main debug: using vout window module "qt"
main debug: looking for inhibit module matching "any": 1 candidates
main debug: using inhibit module "inhibit"
main debug: Opening vout display wrapper
main debug: looking for vout display module matching "any": 12 candidates
main debug: resized to 1920x978
main debug: Buffering 35%
main debug: Buffering 38%
direct3d11 debug: creating Vout EventThread
direct3d11 debug: Win32VoutCreateWindow
main debug: VoutDisplayEvent 'resize' 1920x978
main debug: VoutDisplayEvent 'resize' 1920x904
main debug: Buffering 41%
direct3d11 debug: inclinometer not found. (hr=0x80070490)
direct3d11 debug: created video sub-window
direct3d11 debug: Vout EventThread running
main debug: Buffering 45%
direct3d11 debug: Created the D3D11 device type 1 level b100.
direct3d11 warning: failed to get the 0 MatchingDeviceId (2)
direct3d11 debug: Intel WDDM driver 20.19.15.4835
main debug: Buffering 48%
direct3d11 warning: could not get a IDXGISwapChain3
direct3d11 debug: Using pixel format VA_NV12 for chroma DX11
main debug: VoutDisplayEvent 'resize' 1938x1127
main debug: Buffering 51%
main debug: Buffering 55%
direct3d11 debug: Direct3D11 resources created
direct3d11 debug: Direct3D11 device adapter successfully initialized
direct3d11 debug: Direct3D11 Open Succeeded
main debug: using vout display module "direct3d11"
direct3d11 debug: D3D11 pool succeed with 38 surfaces (1920x1152) context 0x17f108c0
main debug: original format sz 1920x1088, of (0,0), vsz 1920x1080, 4cc DX11, sar 1:1, msk r0x0 g0x0 b0x0
main debug: removing module "freetype"
direct3d11 debug: Detected size change 1607x904
main debug: looking for hw decoder module matching "any": 2 candidates
d3d11va warning: failed to get the 0 MatchingDeviceId (2)
d3d11va debug: Intel WDDM driver 20.19.15.4835
d3d11va debug: Reusing Direct3D11 device
d3d11va debug: CreateDevice succeed
main debug: Buffering 58%
d3d11va debug: - 'MPEG-2 variable-length decoder' is supported
d3d11va debug: - 'MPEG-2 inverse discrete cosine transform' is supported
d3d11va debug: - 'VC-1 variable-length decoder' is supported
d3d11va debug: - 'VC-1 variable-length decoder 2 (Intel)' is supported
d3d11va debug: - 'VC-1 variable-length decoder (Intel)' is supported
d3d11va debug: - 'Windows Media Video 9 IDCT' is supported
d3d11va debug: - 'VC-1 inverse discrete cosine transform' is supported
d3d11va debug: - 'H.264 variable-length decoder, no film grain technology' is supported
d3d11va debug: - 'H.264 stereo high profile, mbs flag set' is supported
d3d11va debug: - 'H.264 stereo high profile' is supported
d3d11va debug: - 'H.264 multiview high profile' is supported
d3d11va debug: - 'H.264 scalable video coding, Scalable Constrained Baseline Profile' is supported
d3d11va debug: - 'H.264 scalable video coding, Scalable Constrained High Profile' is supported
d3d11va debug: - 'Unknown decoder 0x91cd2d6e-0x897b-0x4fa1-0xb0d751dc88010e0a' is supported
d3d11va debug: - 'Unknown decoder 0x442b942a-0xb4d9-0x4940-0xbc45a882e5f919f3' is supported
d3d11va debug: - 'Unknown decoder 0x97688186-0x56a8-0x4094-0xb543fc9daaa49f4b' is supported
d3d11va debug: - 'Unknown decoder 0xc346e8a3-0xcbed-0x4d27-0x87cca70eb4dc8c27' is supported
d3d11va debug: - 'Unknown decoder 0xffc79924-0x5eaf-0x4666-0xa73606190f281443' is supported
d3d11va debug: - 'Unknown decoder 0xf416f7bd-0x098a-0x4cf1-0xa11bce54959ca03d' is supported
d3d11va debug: - 'Unknown decoder 0xbf44dacd-0x217f-0x4370-0xa383d573bc56707e' is supported
d3d11va debug: - 'Unknown decoder 0xd41289c2-0xecf3-0x4ede-0x9a043bbf9068a629' is supported
d3d11va debug: - 'Unknown decoder 0x2364d06a-0xf67f-0x4186-0xaed062b99e1784f1' is supported
d3d11va debug: - 'Unknown decoder 0x8c56eb1e-0x2b47-0x466f-0x8d337dbcd63f3df2' is supported
d3d11va debug: - 'HEVC Main profile' is supported
d3d11va debug: - 'Unknown decoder 0x75fc75f7-0xc589-0x4a07-0xa25b72e03b0383b3' is supported
d3d11va debug: - 'HEVC Main 10 profile' is supported
d3d11va debug: - 'VP9 profile Intel' is supported
d3d11va debug: - 'Unknown decoder 0x49761bec-0x4b63-0x4349-0xa5ff87ffdf088466' is supported
d3d11va debug: Trying to use 'H.264 variable-length decoder, no film grain technology' as input
d3d11va debug: NV12 output is supported for decoder H.264 variable-length decoder, no film grain technology.
d3d11va debug: Using output format NV12 for decoder H.264 variable-length decoder, no film grain technology
d3d11va debug: va_pool_SetupDecoder id 27 1920x1088 count: 23
d3d11va debug: using external surface pool
d3d11va debug: ID3D11VideoDecoderOutputView succeed with 23 surfaces (1920x1088)
d3d11va debug: we got 6 decoder configurations
d3d11va debug: configuration[0] ConfigBitstreamRaw 2
d3d11va debug: configuration[1] ConfigBitstreamRaw 1
d3d11va debug: configuration[2] ConfigBitstreamRaw 2
d3d11va debug: configuration[3] ConfigBitstreamRaw 2
d3d11va debug: configuration[4] ConfigBitstreamRaw 1
d3d11va debug: configuration[5] ConfigBitstreamRaw 1
d3d11va debug: DxCreateDecoderSurfaces succeed
main debug: using hw decoder module "d3d11va"
avcodec info: Using D3D11VA (Intel(R) HD Graphics 5500, vendor 8086(Intel), device 1616, revision 9) for hardware decoding
main debug: Buffering 61%
main debug: Buffering 65%
main debug: Buffering 68%
main debug: Buffering 71%
main debug: Buffering 75%
main debug: Buffering 78%
main debug: Received first picture
main debug: Buffering 81%
main debug: Buffering 85%
main debug: Buffering 88%
main debug: Buffering 91%
main debug: Buffering 95%
main debug: Buffering 98%
main debug: Stream buffering done (1017 ms in 871 ms)
main debug: Decoder wait done in 0 ms
main debug: auto hiding mouse cursor
main error: ES_OUT_SET_(GROUP_)PCR is called too late (pts_delay increased to 1000 ms)
main debug: ES_OUT_RESET_PCR called
main debug: Buffering 3%
main debug: Buffering 6%
avcodec debug: reusing decoder output format 118
main debug: Buffering 9%
main debug: Buffering 13%
main debug: Buffering 16%
main debug: Buffering 19%
main debug: Buffering 23%
main debug: Buffering 26%
main debug: Buffering 29%
main debug: Buffering 33%
main debug: Buffering 36%
main debug: Buffering 39%
main debug: Buffering 43%
main debug: Buffering 46%
main debug: Buffering 49%
main debug: Buffering 53%
main debug: Buffering 56%
main debug: Buffering 59%
main debug: Buffering 63%
main debug: Buffering 66%
main debug: Buffering 69%
main debug: Buffering 73%
main debug: Buffering 76%
main debug: Buffering 79%
main debug: Buffering 83%
main debug: Buffering 86%
main debug: Buffering 90%
main debug: Buffering 93%
main debug: Buffering 96%
main debug: Buffering 99%
main debug: Stream buffering done (1032 ms in 200 ms)
main warning: picture is too late to be displayed (missing 37 ms)
main debug: picture might be displayed late (missing 4 ms)
main warning: picture is too late to be displayed (missing 420 ms)
main warning: picture is too late to be displayed (missing 387 ms)
main warning: picture is too late to be displayed (missing 353 ms)
main warning: picture is too late to be displayed (missing 320 ms)
main warning: picture is too late to be displayed (missing 287 ms)
main warning: picture is too late to be displayed (missing 253 ms)
main warning: picture is too late to be displayed (missing 220 ms)
main warning: picture is too late to be displayed (missing 163 ms)
main warning: picture is too late to be displayed (missing 129 ms)
main warning: picture is too late to be displayed (missing 96 ms)
main warning: picture is too late to be displayed (missing 63 ms)
main warning: picture is too late to be displayed (missing 29 ms)
main debug: picture might be displayed late (missing 0 ms)
main warning: picture is too late to be displayed (missing 1773 ms)
main warning: picture is too late to be displayed (missing 1740 ms)
main warning: picture is too late to be displayed (missing 62 ms)
main warning: picture is too late to be displayed (missing 61 ms)
main warning: picture is too late to be displayed (missing 27 ms)
main error: ES_OUT_SET_(GROUP_)PCR is called too late (pts_delay increased to 3220 ms)
main debug: Buffering 1%
main debug: Buffering 4%
main debug: Buffering 7%
main debug: Buffering 8%
main debug: Buffering 10%
main debug: Buffering 11%
main debug: Buffering 12%
main debug: Buffering 14%
main debug: Buffering 15%
main debug: Buffering 17%
main debug: Buffering 18%
main debug: Buffering 20%
main debug: Buffering 21%
main debug: Buffering 22%
main debug: Buffering 24%
main debug: Buffering 25%
main debug: Buffering 27%
main debug: Buffering 32%
main debug: Buffering 34%
main debug: Buffering 37%
main debug: Buffering 40%
main debug: Buffering 42%
main debug: Buffering 44%
main debug: Buffering 47%
main debug: Buffering 50%
main debug: Buffering 52%
main debug: Buffering 54%
main debug: Buffering 57%
main debug: Buffering 60%
main debug: Buffering 62%
main debug: Buffering 64%
main debug: Buffering 67%
main debug: Buffering 70%
main debug: Buffering 72%
main debug: Buffering 74%
main debug: Buffering 77%
main debug: Buffering 80%
main debug: Buffering 82%
main debug: Buffering 84%
main debug: Buffering 87%
main debug: Buffering 92%
main debug: Buffering 94%
main debug: Buffering 97%
main debug: Stream buffering done (3233 ms in 80 ms)
main error: buffer deadlock prevented
avcodec warning: More than 11 late frames, dropping frame
main warning: picture is too late to be displayed (missing 3623 ms)
main warning: picture is too late to be displayed (missing 3590 ms)
main warning: picture is too late to be displayed (missing 3557 ms)
main warning: picture is too late to be displayed (missing 3523 ms)
main warning: picture is too late to be displayed (missing 3483 ms)
main warning: picture is too late to be displayed (missing 3450 ms)
main warning: picture is too late to be displayed (missing 422 ms)
main warning: picture is too late to be displayed (missing 355 ms)
main warning: picture is too late to be displayed (missing 288 ms)
main warning: picture is too late to be displayed (missing 222 ms)
main warning: picture is too late to be displayed (missing 188 ms)
main warning: picture is too late to be displayed (missing 155 ms)
main warning: picture is too late to be displayed (missing 122 ms)
main warning: picture is too late to be displayed (missing 88 ms)
main warning: picture is too late to be displayed (missing 55 ms)
main warning: picture is too late to be displayed (missing 22 ms)
main error: ES_OUT_SET_(GROUP_)PCR is called too late (pts_delay increased to 3510 ms)
main debug: Buffering 30%
main debug: Buffering 89%
main debug: Stream buffering done (3534 ms in 80 ms)
main debug: Decoder wait done in 10 ms
main warning: picture is too late to be displayed (missing 290 ms)
main warning: picture is too late to be displayed (missing 256 ms)
main warning: picture is too late to be displayed (missing 223 ms)
main warning: picture is too late to be displayed (missing 190 ms)
main warning: picture is too late to be displayed (missing 157 ms)
main warning: picture is too late to be displayed (missing 124 ms)
main warning: picture is too late to be displayed (missing 91 ms)
main warning: picture is too late to be displayed (missing 57 ms)
main warning: picture is too late to be displayed (missing 24 ms)
main warning: picture is too late to be displayed (missing 25 ms)
main debug: picture might be displayed late (missing 5 ms)
main debug: picture might be displayed late (missing 3 ms)
main error: ES_OUT_SET_(GROUP_)PCR is called too late (pts_delay increased to 3771 ms)
main debug: Stream buffering done (3800 ms in 40 ms)
main warning: picture is too late to be displayed (missing 1295 ms)
main warning: picture is too late to be displayed (missing 1262 ms)
main warning: picture is too late to be displayed (missing 1228 ms)
main warning: picture is too late to be displayed (missing 1195 ms)
main warning: picture is too late to be displayed (missing 1993 ms)
main warning: picture is too late to be displayed (missing 1959 ms)
main warning: picture is too late to be displayed (missing 1926 ms)
main warning: picture is too late to be displayed (missing 1893 ms)
main warning: picture is too late to be displayed (missing 1859 ms)
main warning: picture is too late to be displayed (missing 1824 ms)
main warning: picture is too late to be displayed (missing 326 ms)
main warning: picture is too late to be displayed (missing 259 ms)
main warning: picture is too late to be displayed (missing 193 ms)
main warning: picture is too late to be displayed (missing 126 ms)
main warning: picture is too late to be displayed (missing 93 ms)
main warning: picture is too late to be displayed (missing 59 ms)
main warning: picture is too late to be displayed (missing 26 ms)
main warning: picture is too late to be displayed (missing 115 ms)
main warning: picture is too late to be displayed (missing 81 ms)
main warning: picture is too late to be displayed (missing 48 ms)
main debug: picture might be displayed late (missing 15 ms)
main warning: picture is too late to be displayed (missing 70 ms)
main warning: picture is too late to be displayed (missing 50 ms)
main warning: picture is too late to be displayed (missing 17 ms)
main warning: picture is too late to be displayed (missing 60 ms)
main warning: picture is too late to be displayed (missing 41 ms)
main debug: picture might be displayed late (missing 8 ms)
main debug: picture might be displayed late (missing 6 ms)
live555 warning: no data received in 10s, eof ?
main debug: EOF reached
main debug: waiting decoder fifos to empty
main warning: picture is too late to be displayed (missing 6697 ms)
main warning: picture is too late to be displayed (missing 6674 ms)
main debug: saving a free vout
main debug: reusing provided vout
main debug: removing module "live555"
main debug: dead input
main debug: changing item without a request (current 2/3)
main debug: nothing to play
main debug: destroying useless vout
main debug: removing module "direct3d11"
direct3d11 debug: Direct3D11 resources destroyed
qt debug: IM: Deleting the input
direct3d11 debug: Direct3D11 device adapter closed
direct3d11 error: SetThumbNailClip failed: 0x800706f4
direct3d11 debug: Win32 Vout EventThread terminating
direct3d11 debug: Win32VoutCloseWindow
direct3d11 debug: WinProc WM_DESTROY
main debug: removing module "inhibit"
qt debug: releasing video...
qt debug: Video is not needed anymore
main debug: removing module "yuvp"
main debug: removing module "swscale"
Could you give some suggestions? Thanks in advance.
