Gstreamer: ipcpipeline or proxy
I am using the UBUNTU 16.04 on the Jetson TX2. I cannot use the Gstreamer elements ipcpipeline or proxy which are part of the latest GStreamer releases.
Am I supposed to find them?
https://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-plugins-bad/html/gst-plugins-bad-plugins-proxysink.html#GstProxySink-struc
https://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-plugins-bad/html/gst-plugins-bad-plugins-plugin-ipcpipeline.html
The gstreamer version is 1.14.1 in r32.1. You may follow [GTREAMER BUILD INSTRUCTION] to upgrade to 1.16.0 and try again.
I have tried to install 1.14.2 on 28.1. Though it was installed I could not connect to the GStreamer libraries from QT, althouhg I’ve set all Env params per the installation procedure.
QT is still pulling the libraries from /usr/lib and not from the the directory where I installed the new GStreamer version.
Any suggestions?
NVIDIA plugins on r28.1 is built with gstreamer v1.8.3. Deviation in header files may lead to the failure. Suggest you base on r32.1/r32.2 for the upgrade.
