Hello;
I did install apt gstreamer1.0-vaapi, however I can’t inspect vaapi or use vaapi elements, is it not available for jetson environment?
Is there a way for me to use vaapi plugin on jetson tx2 environment?
Many thanks;
Hello;
Many thanks;
Hi alperkzlkm,
AFAIK, this is not supported. The feature was reviewed before, but not adopted. The status is pending currently.
vaapi is a 3rdparty package and other users may share you experience. One thing you may try is to clean the cache and run gst-inspect-1.0 again.
sudo rm ~/.cache/gstreamer-1.0/registry.aarch64.bin
