Please execute the steps to run system at maximum performance mode. And check if there is improvement:
- Run $ sudo nvpmodel -m 0 and $ sudo jetson_clocks
- Set the property to hardware encoder:
maxperf-enable : Enable or Disable Max Performance mode
flags: readable, writable, changeable only in NULL or READY state
Boolean. Default: false
- Enable VIC engine at maximum clock:
Nvvideoconvert issue, nvvideoconvert in DS4 is better than Ds5? - #3 by DaneLLL
You can check CPU/GPU/NVENC status by executing sudo tegrastats
