It looks like some names have just changed:
$ gst-inspect-1.0 | grep srt
dtls: dtlssrtpdemux: DTLS SRTP Demultiplexer
dtls: dtlssrtpenc: DTLS-SRTP Encoder
dtls: dtlssrtpdec: DTLS-SRTP Decoder
subparse: subparse_typefind: srt, sub, mpsub, mdvd, smi, txt, dks, vtt
subenc: srtenc: Srt encoder
srtp: srtpdec: SRTP decoder
srtp: srtpenc: SRTP encoder
I would suggest looking at the documentation for those with gst-inspect, like:
$ gst-inspect-1.0 srtpenc
Factory Details:
Rank none (0)
Long-name SRTP encoder
Klass Filter/Network/SRTP
Description A SRTP and SRTCP encoder
Author Gabriel Millaire <millaire.gabriel@collabora.com>
Plugin Details:
Name srtp
Description GStreamer SRTP
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstsrtp.so
Version 1.14.5
License LGPL
Source module gst-plugins-bad
Source release date 2019-05-29
Binary package GStreamer Bad Plugins (Ubuntu)
Origin URL https://launchpad.net/distros/ubuntu/+source/gst-plugins-bad1.0
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstSrtpEnc
Pad Templates:
SINK template: 'rtcp_sink_%u'
Availability: On request
Capabilities:
application/x-rtcp
SRC template: 'rtcp_src_%u'
Availability: Sometimes
Capabilities:
application/x-srtcp
SINK template: 'rtp_sink_%u'
Capabilities:
application/x-rtp
SRC template: 'rtp_src_%u'
Capabilities:
application/x-srtp
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
none
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "srtpenc0"
parent : The parent of the object
Object of type "GstObject"
key : Master key (minimum of 30 and maximum of 46 bytes)
flags: readable, writable, changeable in NULL, READY, PAUSED or PLAYING state
Boxed pointer of type "GstBuffer"
rtp-cipher : RTP Cipher
Enum "GstSrtpCipherType" Default: 1, "aes-128-icm"
(0): null - GST_SRTP_CIPHER_NULL
(1): aes-128-icm - GST_SRTP_CIPHER_AES_128_ICM
(2): aes-256-icm - GST_SRTP_CIPHER_AES_256_ICM
rtp-auth : RTP Authentication
Enum "GstSrtpAuthType" Default: 2, "hmac-sha1-80"
(0): null - GST_SRTP_AUTH_NULL
(1): hmac-sha1-32 - GST_SRTP_AUTH_HMAC_SHA1_32
(2): hmac-sha1-80 - GST_SRTP_AUTH_HMAC_SHA1_80
rtcp-cipher : RTCP Cipher
rtcp-auth : RTCP Authentication
random-key : Generate a random key if TRUE
Boolean. Default: false
replay-window-size : Size of the replay protection window
Unsigned Integer. Range: 64 - 32768 Default: 128
allow-repeat-tx : Whether retransmissions of packets with the same sequence number are allowed(Note that such repeated transmissions must have the same RTP payload, or a severe security weakness is introduced!)
stats : Various statistics
flags: readable
Boxed pointer of type "GstStructure"
streams: < >
Element Signals:
"pad-added" : void user_function (GstElement* object,
GstPad* arg0,
gpointer user_data);
"pad-removed" : void user_function (GstElement* object,
GstPad* arg0,
"no-more-pads" : void user_function (GstElement* object,
"soft-limit" : void user_function (GstElement* object,
edit: note that subparse and srtenc are probably not what you’re looking for. Confusingly, .srt is a very popular subtitle format.
