Following Pipeline works locally for streaming rtsp video to a TCP sink:
gst-launch-1.0 rtspsrc location='rtsp://admin:fakepass@192.168.2.150:554/cam/realmonitor?channel=1&subtype=1' ! decodebin ! queue ! videoconvert ! x264enc byte-stream=true threads=4 key-int-max=25 ! mpegtsmux ! tcpserversink port=8554 host=0.0.0.0
but as soon as I add in motioncells I no longer get any output video on the TCP stream:
gst-launch-1.0 rtspsrc location='rtsp://admin:fakepass@192.168.2.150:554/cam/realmonitor?channel=1&subtype=1' ! decodebin ! queue ! videoconvert ! motioncells sensitivity=1 motioncellthickness=3 cellscolor=255,0,0 usealpha=false gridx=8 gridy=8 ! queue ! videoconvert ! queue ! x264enc tune=zerolatency byte-stream=true threads=4 key-int-max=25 ! mpegtsmux ! tcpserversink port=8554 host=0.0.0.0
The output resolution is equal to the input resolution, but there are no images inside.
If I use xvimagesink instead of tcpserversink I locally get the correct stream with the motioncells overlay.
How can I stream the working “xvimagesink” output to my tcpsink?
