GStreamer (Nvidia Accelerated GStreamer) pipeline getting stuck while trying to simultaneously preview and write to disk
Jetson Xavier
• DeepStream Version
6
4.6.1
question, bug?
I am trying to create a pipeline with a camera where I can simultaneously preview and write to the file.
                                  ------> queue ---->  fakesink
usb camera ---- Tee --
                                ------> queue -----> nvvideoconvert ---->  nvegltransform ----> nveglglessink ** Working  Fine **
                                  ------> queue ---->  nvv4l2h264enc   ----> fakesink
usb camera---- Tee --
                                ------> queue -----> nvvideoconvert ---->  nvegltransform ----> nveglglessink ** Not Working   **
Here is a python file with sample code to demonstrate the issue,
camsrc_net_test_filesink_and_preview_forum.py (6.5 KB)
                                  ------> queue ---->  nvv4l2h264enc   ----> filesink  ** What I want **
usb camera---- Tee
                                ------> queue -----> nvvideoconvert ---->  nvegltransform ----> nveglglessink ** What I Want   **
Hi.
Please find the description of the problem above. Basically I would like to run a data logger while previewing the stream. however when I build the pipeline I prefer the video frame freezes and the capture file does not accumulate any footage. they both work independently without an issue (when preview and logging run separately) I wonder if this is a GStreamer limitation or if I’m doing something fundamentally wrong . previously I’ve got other combinations working fine e.g. deepstream pipeline running inference and parallel RTSP streams of both raw and processed/annotated video.
Cheers,
Ganindu.
Hi @ganinduN , could you try the following 2 methods?
1.the reason may be your camera data format is not matching the nvv4l2h264enc data format. So you can add a nvconvert plugin between them.
2.set the nveglglessink plugin “sync” property to FALSE.
Hi @yuweiw,
Thanks a lot for the answer!! you were very close.
To unfreeze the nveglglessink the trick is to set sink.set_property('async', False)
However the answer to sandwiching nvvideoconvert blocks is slightly not straightforward as it depends on the upstream compatibility. In my case most of the time I use LVDS cameras that go through the MIPI interface therefore I get video/x-raw(memory:NVMM) that is happily compatible with the downstream hardware accelerated blocks. If you use a usb cam for example you may have video/x-raw so you may require a video/x-raw -- > video/x-raw(memory:NVMM) conversion which nvvideoconvert take care of.
Hope this helps! (definitely helped myself)
I’ve added a working code that works with a usb cam, please read the comments for caveats!
Cheers,
Ganindu.
camsrc_net_test_filesink_and_preview_forum_working.py (6.1 KB)
