I am using gstreamer in my project on a Jetson Nano rev B01, but I have an issue with nvoverlaysink: it hangs after displaying New clock: GstSystemClock
without opening the window with the video feed as it should.
Running gst-launch-1.0 videotestsrc ! ximagesink
works as intended (displaying the video test feed, after outputting New clock: GstSystemClock), while running gst-launch-1.0 videotestsrc ! nvoverlaysink
output exactly the same lines, but does not open the window.
@Honey_Patouceul Adding nvvidconv did not make any difference unfortunately.
@DaneLLL Both sinks work, thank you! I have questions about nvoverlaysink still:
I cannot find any resource telling that nvoverlaysink is not window-based, could you link a documentation please? (not doubting you, I am looking for documentation ^^)
I just discovered that it is deprecated in Jetson Linux Driver Package Release 32.1, according to this documentation, but the autovideosink still tries to use nvoverlaysink.
gst-launch-1.0 -v -m videotestsrc ! autovideosink
let me see this. At some point, there is the message: Got message #26 from pad "autovideosink0-actual-sink-nvoverlay:sink" [...]
Are you using a DP monitor ?
I have no Nano for checking, but my guess would be that it works… on the wrong display.
You may try changing the display-id property of nvoverlaysink:
@Honey_Patouceul Yes I am using a DP monitor (and it is the only monitor connected to my Nano). Setting the display-id to 1 makes the nvoverlaysink work.
But why does it not work without changing that display-id? Which monitor could display-id=0 (or whatever the default value is) correspond to?
@DaneLLL If I understand correctly, gstreamer elements starting with “nv” are made by Nvidia, so they should not be documented by gstreamer (and I cannot find them on their documentation)
