Hi all,
I have a gstreamer pipeline that I feed from an appsrc and feeds into a display branch. (Please see the attached png, please ignore the fakesink branch
). The appsrc is fed from an USB3 camera with the following pseudocode:
m_cam.getNextFrame (m_rawImageSize, &m_RawImage[0]); //rawImageSize is computed before. This is a blocking call
getFormattedImageSize(&m_RawImage[0], IMAGE_FORMAT_TIFF, &m_encodedImageSize);
* For some extremely weird reason, the following line of code makes the error
* "NVMAP_IOC_WRITE failed: Interrupted system call"
* go away. It is generated by a nvvidconv element in the gstreamer pipeline. The error itself doesn't seem
* to have any effect on the moviefile it generates, but it is still very strange.
m_encodedImage = std::vector<char>(m_encodedImageSize);
GstBuffer *buffer;
GstMapInfo map;
GstFlowReturn ret;
buffer = gst_buffer_new_and_alloc(m_rawImageSize);
gst_buffer_map(buffer, &map, GST_MAP_WRITE);
memcpy((char *) map.data, &m_RawImage[0], m_rawImageSize);
gst_buffer_unmap(buffer, &map);
GST_BUFFER_DURATION(buffer) = gst_util_uint64_scale_int(1, GST_SECOND, 25);
gst_app_src_push_buffer((GstAppSrc *) appsrc, buffer);
In principle this all works fine (the image is displayed correctly), but I still get the
error thrown at me if I don’t allocate that m_encodedImage vector (see the code). The weird thing is, I don’t use that vector at all anywhere, so I would prefer to ditch it (it’s there from earlier work), but I first want to understand what exactly is happening. I’ve played around with the pipeline and the error is generated by the nvvidconv component sitting before the nvdrmvideosink. Any ideas?
