Gstreamer of AP1302 Previews Glitch Screen
I’m developing a driver for On semi’s ap1302. It doesn’t gave any error or anything but when I execute gstreamer command (gst-launch-1.0 v4l2src device=/dev/video0 ! “video/x-raw, format=(string)UYVY, width=(int)1280, height=(int)720, framerate=30/1” ! videoconvert ! ximagesink sync=false | dmesg -w) it outputs as follows:
Initially I thought it was a format missmatch, but after checking with developer kit of ap1302, it seems all correct.
Can you gave me any directions to where to look ?
Did you dump the frame data from v4l2-ctl to confirm it.
Does any error message from dmesg?
Hi Shane,
When I execute the following:
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=“UYVY” --set-ctrl bypass_mode=0 --device=/dev/video0 --stream-skip=100 --stream-count=1 --stream-mmap --stream-to=file.raw
This is the outcome:
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.00 fps
dmesg:
[ 6935.399625] tevi-ap1302 7-003c: camera_common_mclk_enable: enable MCLK with 48000000 Hz
[ 6935.399745] tevi-ap1302 7-003c: camera_common_dpd_disable: csi 0
[ 6935.399793] tevi-ap1302 7-003c: camera_common_dpd_disable: csi 1
[ 6935.399811] tevi-ap1302 7-003c: v4l2sd_stream++ enable 1
[ 6935.399822] tevi-ap1302 7-003c: sensor_set_mode() , {1}, fmt_width=1920, fmt_height=1080
[ 6935.399835] tevi-ap1302 7-003c: sensor_start_streaming()
[ 6935.399842] vi 54080000.vi: Calibrate csi port 0
[ 6935.399992] tevi-ap1302 7-003c: v4l2sd_stream++ enable 0
[ 6935.399999] tevi-ap1302 7-003c: sensor_stop_streaming()
[ 6935.400048] tevi-ap1302 7-003c: camera_common_dpd_enable: csi 0
[ 6935.400082] tevi-ap1302 7-003c: camera_common_dpd_enable: csi 1
[ 6935.400087] tevi-ap1302 7-003c: camera_common_mclk_disable: disable MCLK
[ 6935.400105] tevi-ap1302 7-003c: camera_common_mclk_enable: enable MCLK with 48000000 Hz
[ 6935.400139] tevi-ap1302 7-003c: camera_common_dpd_disable: csi 0
[ 6935.400171] tevi-ap1302 7-003c: camera_common_dpd_disable: csi 1
[ 6935.401192] tevi-ap1302 7-003c: camera_common_try_fmt: size 1920 x 1080
[ 6935.401223] tevi-ap1302 7-003c: camera_common_s_fmt(8207) size 1920 x 1080
[ 6935.401243] tevi-ap1302 7-003c: camera_common_try_fmt: size 1920 x 1080
[ 6935.423299] vi 54080000.vi: cil_settingtime was autocalculated
[ 6935.423305] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 6935.423323] tevi-ap1302 7-003c: v4l2sd_stream++ enable 1
[ 6935.423328] tevi-ap1302 7-003c: sensor_set_mode() , {1}, fmt_width=1920, fmt_height=1080
[ 6935.423337] tevi-ap1302 7-003c: sensor_start_streaming()
[ 6938.888379] tevi-ap1302 7-003c: v4l2sd_stream++ enable 0
[ 6938.888394] tevi-ap1302 7-003c: sensor_stop_streaming()
[ 6938.905189] tevi-ap1302 7-003c: camera_common_dpd_enable: csi 0
[ 6938.905221] tevi-ap1302 7-003c: camera_common_dpd_enable: csi 1
[ 6938.905226] tevi-ap1302 7-003c: camera_common_mclk_disable: disable MCLK
Did you check the file.raw?
No where does it save ?
I found file.raw but can’t open it. Which command should I use ?
You may need 7yuv tools to open it to check.
I can’t install 7yuv. Are there any alternatives ?
here is the link to a file. Can you check it using 7yuv ?
Unable to show the frames.
I also tried the same method with different formats, but problem still occurs.
The raw data was broken let me suspect the sensor module. Did you verify it on any others platform like PI?
Hi ShaneCCC,
Can device tree settings might be wrong ?
Here is my device tree. I’m using mode 1 of i2c0. Mclk is 4800.
 * Copyright (c) 2018-2019, NVIDIA CORPORATION.  All rights reserved.
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful, but WITHOUT
 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
 * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
 * more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
	host1x {
		vi_base: vi {
			num-channels = <2>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				vi_port0: port@0 {
					reg = <0>;
					// status = "disabled";
					tevi_ap1302_vi_in0: endpoint {
						port-index = <0>;
						bus-width = <2>;
						remote-endpoint = <&tevi_ap1302_csi_out0>;
				vi_port1: port@1 {
					reg = <1>;
					tevi_ap1302_vi_in1: endpoint {
						port-index = <4>;
						bus-width = <2>;
						remote-endpoint = <&tevi_ap1302_csi_out1>;
		csi_base: nvcsi {
			num-channels = <2>;
			#size-cells = <0>;
			csi_chan0: channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					csi_chan0_port0: port@0 {
						reg = <0>;
						tevi_ap1302_csi_in0: endpoint@0 {
							port-index = <0>;
							bus-width = <2>;
							remote-endpoint = <&tevi_ap1302_dual_out0>;
					csi_chan0_port1: port@1 {
						reg = <1>;
						tevi_ap1302_csi_out0: endpoint@1 {
							remote-endpoint = <&tevi_ap1302_vi_in0>;
			csi_chan1: channel@1 {
				reg = <1>;
				ports {
					#size-cells = <0>;
					csi_chan1_port0: port@2 {
						reg = <0>;
						tevi_ap1302_csi_in1: endpoint@2 {
							port-index = <4>;
							bus-width = <2>;
							remote-endpoint = <&tevi_ap1302_dual_out1>;
					csi_chan1_port1: port@3 {
						reg = <1>;
						tevi_ap1302_csi_out1: endpoint@3 {
							remote-endpoint = <&tevi_ap1302_vi_in1>;
	cam_i2cmux {
		i2c_0: i2c@0 {
			tevi_ap1302_cam0: tevi_ap1302_a@3c {
				compatible = "tn,tevi-ap1302";
				/* I2C device address */
				reg = <0x3c>;
				/* V4L2 device node location */
				devnode = "video0";
				/* Physical dimensions of sensor */
				// physical_w = "3.680";
				// physical_h = "2.760";
				sensor_model = "tevi-ap1302";
				use_sensor_mode_id = "false";
				* ==== Modes ====
				* A modeX node is required to support v4l2 driver
				* implementation with NVIDIA camera software stack
				* == Signal properties ==
				* phy_mode = "";
				* PHY mode used by the MIPI lanes for this device
				* tegra_sinterface = "";
				* CSI Serial interface connected to tegra
				* Incase of virtual HW devices, use virtual
				* For SW emulated devices, use host
				* pix_clk_hz = "";
				* Sensor pixel clock used for calculations like exposure and framerate
				* readout_orientation = "0";
				* Based on camera module orientation.
				* Only change readout_orientation if you specifically
				* Program a different readout order for this mode
				* == Image format Properties ==
				* active_w = "";
				* Pixel active region width
				* active_h = "";
				* Pixel active region height
				* pixel_t = "";
				* The sensor readout pixel pattern
				* line_length = "";
				* Pixel line length (width) for sensor mode.
				* == Source Control Settings ==
				* Gain factor used to convert fixed point integer to float
				* Gain range [min_gain/gain_factor, max_gain/gain_factor]
				* Gain step [step_gain/gain_factor is the smallest step that can be configured]
				* Default gain [Default gain to be initialized for the control.
				*     use min_gain_val as default for optimal results]
				* Framerate factor used to convert fixed point integer to float
				* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
				* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
				* Default Framerate [Default framerate to be initialized for the control.
				*     use max_framerate to get required performance]
				* Exposure factor used to convert fixed point integer to float
				* For convenience use 1 sec = 1000000us as conversion factor
				* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
				* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
				* Default Exposure Time [Default exposure to be initialized for the control.
				*     Set default exposure based on the default_framerate for optimal exposure settings]
				* gain_factor = ""; (integer factor used for floating to fixed point conversion)
				* min_gain_val = ""; (ceil to integer)
				* max_gain_val = ""; (ceil to integer)
				* step_gain_val = ""; (ceil to integer)
				* default_gain = ""; (ceil to integer)
				* Gain limits for mode
				* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
				* min_exp_time = ""; (ceil to integer)
				* max_exp_time = ""; (ceil to integer)
				* step_exp_time = ""; (ceil to integer)
				* default_exp_time = ""; (ceil to integer)
				* Exposure Time limits for mode (sec)
				* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
				* min_framerate = ""; (ceil to integer)
				* max_framerate = ""; (ceil to integer)
				* step_framerate = ""; (ceil to integer)
				* default_framerate = ""; (ceil to integer)
				* Framerate limits for mode (fps)
				* embedded_metadata_height = "";
				* Sensor embedded metadata height in units of rows.
				* If sensor does not support embedded metadata value should be 0.
				mode0 { /* AP1302_MODE_1280x720_60FPS */
					//mclk_khz = "24000";
					mclk_khz = "48000";
					num_lanes = "2";
					phy_mode = "DPHY";
					discontinuous_clk = "yes";
					dpcm_enable = "false";
					cil_settletime = "0";
					active_w = "1280";
					active_h = "720";
					pixel_t = "yuv_uyvy16";
					readout_orientation = "90";
					line_length = "1280";
					inherent_gain = "1";
					mclk_multiplier = "9.33";
					pix_clk_hz = "182400000";
					gain_factor = "16";
					framerate_factor = "1000000";
					exposure_factor = "1000000";
					min_gain_val = "16"; /* 1.00x */
					max_gain_val = "170"; /* 10.66x */
					step_gain_val = "1";
					default_gain = "16"; /* 1.00x */
					min_hdr_ratio = "1";
					max_hdr_ratio = "1";
					min_framerate = "2000000"; /* 2.0 fps */
					max_framerate = "60000000"; /* 60.0 fps */
					step_framerate = "1";
					default_framerate = "60000000"; /* 60.0 fps */
					min_exp_time = "13"; /* us */
					max_exp_time = "683709"; /* us */
					step_exp_time = "1";
					default_exp_time = "2495"; /* us */
					embedded_metadata_height = "2";
				mode1 { /* AP1302_MODE_1920x1080_30FPS */
					mclk_khz = "48000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "1920";
					active_h = "1080";
					//readout_orientation = "90";
					line_length = "4612";
					//pix_clk_hz = "182400000";
					pix_clk_hz = "364800000";
					gain_factor = "16";
					max_framerate = "30000000"; /* 30.0 fps */
					default_framerate = "30000000"; /* 30.0 fps */
				mode2 { /* AP1302_MODE_1920x1080_30FPS */
					mclk_khz = "24000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "2560";
					active_h = "1440";
					gain_factor = "16";
				mode3 { /* AP1302_MODE_1920x1080_30FPS */
					mclk_khz = "24000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "3840";
					active_h = "2160";
					gain_factor = "16";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						tevi_ap1302_dual_out0: endpoint {
							port-index = <0>;
							bus-width = <4>;
							remote-endpoint = <&tevi_ap1302_csi_in0>;
		i2c_1: i2c@1 {
			tevi_ap1302_cam1: tevi_ap1302_e@3c {
				reg = <0x3c>;
				devnode = "video1";
				* ==== Modes ====
				* phy_mode = "";
				* pix_clk_hz = "";
				* active_w = "";
				* active_h = "";
				* pixel_t = "";
				* line_length = "";
					mclk_khz = "24000";
					num_lanes = "2";
					tegra_sinterface = "serial_e";
					phy_mode = "DPHY";
					active_w = "1280";
					active_h = "720";
					gain_factor = "16";
					max_framerate = "30000000"; /* 21.0 fps */
					default_framerate = "30000000"; /* 21.0 fps */
					embedded_metadata_height = "0";
					mclk_khz = "24000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "1920";
					active_h = "1080";
					gain_factor = "16";
					mclk_khz = "24000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "2560";
					active_h = "1440";
					gain_factor = "16";
					mclk_khz = "24000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "3840";
					active_h = "2160";
					gain_factor = "16";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						tevi_ap1302_dual_out1: endpoint {
							port-index = <4>;
							bus-width = <2>;
							remote-endpoint = <&tevi_ap1302_csi_in1>;
	lens_ap1302@RBPCV2 {
		min_focus_distance = "0.0";
		hyper_focal = "0.0";
		focal_length = "3.04";
		f_number = "2.0";
		aperture = "0.0";
	tcp: tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		* Physical settings to calculate max ISO BW
		* num_csi_lanes = <>;
		* Total number of CSI lanes when all cameras are active
		* max_lane_speed = <>;
		* Max lane speed in Kbit/s
		* min_bits_per_pixel = <>;
		* Min bits per pixel
		* vi_peak_byte_per_pixel = <>;
		* Max byte per pixel for the VI ISO case
		* vi_bw_margin_pct = <>;
		* Vi bandwidth margin in percentage
		* max_pixel_rate = <>;
		* Max pixel rate in Kpixel/s for the ISP ISO case
		* isp_peak_byte_per_pixel = <>;
		* Max byte per pixel for the ISP ISO case
		* isp_bw_margin_pct = <>;
		* Isp bandwidth margin in percentage
		num_csi_lanes = <4>;
		max_lane_speed = <1500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		//max_pixel_rate = <240000>;
		max_pixel_rate = <480000>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		 * The general guideline for naming badge_info contains 3 parts, and is as follows,
		 * The first part is the camera_board_id for the module; if the module is in a FFD
		 * platform, then use the platform name for this part.
		 * The second part contains the position of the module, ex. "rear" or "front".
		 * The third part contains the last 6 characters of a part number which is found
		 * in the module's specsheet from the vendor.
		modules {
			cam_module0: module0 {
				badge = "porg_front_RBPCV2";
				position = "front";
				orientation = "1";
				cam_module0_drivernode0: drivernode0 {
					pcl_id = "v4l2_sensor";
					devname = "ap1302 7-003c";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/tevi_ap1302_a@3c";
				cam_module0_drivernode1: drivernode1 {
					pcl_id = "v4l2_lens";
					proc-device-tree = "/proc/device-tree/lens_ap1302@RBPCV2/";
			cam_module1: module1 {
				badge = "porg_rear_RBPCV2";
				position = "rear";
				orientation = "1";
				cam_module1_drivernode0: drivernode0 {
					devname = "ap1302 8-003c";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/tevi_ap1302_e@3c";
				cam_module1_drivernode1: drivernode1 {
I don’t think it could be device tree cause the problem.
