• Hardware Platform: Jetson Xavier NX
• JetPack Version: 5.0.2
I have a PLAYING
pipeline to which I’m trying to link a recording bin containing nvv4l2h264enc
, the problem is that this immediately halts the pipeline for unknown reason. If I replace the encoder to x264enc
- the linking is successful and the pipeline keeps PLAYING
Additionally, if the bin is linked before the pipeline enters PLAYING
, then everything works just fine.
I’ve been in touch with the GStreamer community through their IRC channel, they state the obvious that any plugins must handle linking in any scenario.
The use case is rather complex (involves enabling/disabling video recording at runtime), but here is a very simple test case which fully demonstrates the issue, this will halt as is but it’s possible to check all scenarios by commenting the defines combination:
#include <sstream>
#include <gst/gst.h>
#define NVV4L2H264ENC
#define LATE_LINK
static gboolean bus_call(GstBus *bus, GstMessage *msg, gpointer data) {
GMainLoop *loop = (GMainLoop *)data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
GST_ERROR ("End of stream\n");
g_main_loop_quit(loop);
break;
case GST_MESSAGE_ERROR: {
gchar *debug;
GError *error;
gst_message_parse_error(msg, &error, &debug);
g_free(debug);
GST_ERROR ("Error: %s\n", error->message);
g_error_free(error);
break;
default:
break;
return TRUE;
int main (int argc, char *argv[])
std::ostringstream launch_stream;
GMainLoop *loop;
GstElement *pipeline, *recording_bin, *input_tee;
GstBus *bus;
guint bus_watch_id;
GstCaps *filtercaps;
GstPad *pad;
GError *err = nullptr;
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
launch_stream
<< "nvv4l2camerasrc ! video/x-raw(memory:NVMM),format=UYVY,width=1280,height=720,framerate=50/1 ! "
<< "videorate max-rate=25 drop-only=true ! "
<< "tee name=input_tee ! "
<< "queue ! "
<< "nvvidconv ! "
<< "nvv4l2h264enc control-rate=constant_bitrate bitrate=3500000 iframeinterval=500 insert-sps-pps=true profile=Main num-B-Frames=0 ratecontrol-enable=true preset-level=UltraFastPreset EnableTwopassCBR=false maxperf-enable=true ! "
<< "h264parse ! "
<< "mpegtsmux alignment=7 ! "
<< "queue ! "
<< "udpsink sync=false host=224.0.0.1 port=5004";
pipeline = gst_parse_launch(launch_stream.str().c_str(), &err);
if (err) {
GST_ERROR ("Failed to parse pipeline: %s\n", err->message);
if (err) g_error_free(err);
return -1;
launch_stream.str("");
launch_stream.clear();
launch_stream
<< "queue ! "
<< "nvvidconv ! "
#ifdef NVV4L2H264ENC
<< "nvv4l2h264enc bitrate=1500000 ! "
#else
<< "x264enc bitrate=1500 ! "
#endif
<< "h264parse ! "
<< "mpegtsmux ! "
<< "filesink location=/tmp/test.ts"; //also tried async=false
input_tee = gst_bin_get_by_name(GST_BIN(pipeline), "input_tee");
recording_bin = gst_parse_bin_from_description(launch_stream.str().c_str(), true, &err);
if (err) {
GST_ERROR ("Failed to parse recording bin: %s\n", err->message);
return -1;
#ifndef LATE_LINK
gst_bin_add(GST_BIN(pipeline), recording_bin);
gst_element_link(input_tee, recording_bin);
gst_element_sync_state_with_parent(recording_bin);
#endif
bus = gst_pipeline_get_bus(GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch(bus, bus_call, loop);
gst_object_unref(bus);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
if (gst_element_get_state (pipeline, NULL, NULL, -1) == GST_STATE_CHANGE_FAILURE) {
GST_ERROR ("Failed to go into PLAYING state");
return -1;
#ifdef LATE_LINK
g_usleep(2000000); //wait 2 seconds
#endif
g_main_loop_run (loop);
g_source_remove (bus_watch_id);
gst_element_set_state (pipeline, GST_STATE_NULL);
gst_object_unref (pipeline);
return 0;
Here is a level-4 runtime log gst-log.txt (115.1 KB), will appreciate any help, it’ll be great if a related Nvidia engineer is able to reproduce this issue.
Thank you!
