Gstreamer pipeline not working
I am facing the similar issue like above, but my problem is I could not even start following command at first time even I replace those so files:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080' ! nvvidconv ! fpsdisplaysink video-sink=fakesink -v
FYI, my orin nano run on l4t r36.4.3 version and it’s upgraded from r35.3.1 via OTA
gstreamer command log:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = true
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-raw(memory:NVMM, meta:GstVideoOverlayComposition), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM, meta:GstVideoOverlayComposition), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:video_sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 2
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:734 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:245 (propagating)
Redistribute latency...
WARNING: from element /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: Pipeline construction is invalid, please add queues.
Additional debug info:
../libs/gst/base/gstbasesink.c(1249): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0:
Not enough buffering available for  the processing deadline of 0:00:00.020000000, add enough queues to buffer  0:00:00.020000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element "pipeline0".
Execution ended after 0:00:04.014722755
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
Freeing pipeline ...
nvargus daemon log:
Mar 10 09:28:30 tegra-ubuntu systemd[1]: Started Argus daemon.
Mar 10 09:29:13 tegra-ubuntu nvargus-daemon[833]: === NVIDIA Libargus Camera Service (0.99.33)=== Listening for connections...=== gst-launch-1.0[2479]: Connection established (FFFFB7D9B840)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Mar 10 09:29:13 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function verifyDeviceCaps(), line 206)
Mar 10 09:29:13 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error ModuleNotPresent:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 66)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: ---- imager: No override file found. ----
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: initializeDevNode: Failed to open dev node '/dev/camera/video1'; No such file or directory, trying alternate default location
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error BadParameter: Control 10094858 not found (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findControlById(), line 1874)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error BadParameter:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function getControlRange(), line 331)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: initialize: focus query failed
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function open(), line 205)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 722)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 455)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 382)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function getSource(), line 554)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: initializeDevNode: Failed to open dev node '/dev/camera/video2'; No such file or directory, trying alternate default location
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error NotSupported: Must be capture/output devices (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function setActiveBufferType(), line 813)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error NotSupported:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 68)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: (NvOdmDevice) Error NotSupported:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorNonViCsi.cpp, function initialize(), line 146)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor_usb
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor_usb
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: NvPclStartPlatformDrivers: Failed to start module drivers
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: NvPclStateControllerOpen: Failed ImagerGUID 3. (error 0x2)
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: NvPclOpen: PCL Open Failed. Error: 0xf
Mar 10 09:29:14 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 725)
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: === gst-launch-1.0[2479]: CameraProvider initialized (0xffffb0b01c60)SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 0 draining session frameStart events 3
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]:  (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 529)
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Sensor GUID 1 is in error state. Skipping requests, capture sequence ID = 1 continue draining session frameStart events 2
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]:  (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 543)
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Sensor GUID 1 is in error state. Skipping requests, capture sequence ID = 2 continue draining session frameStart events 1
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Sensor 1 already in same state
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]:  (in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 0 draining session frameEnd events 3
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]:  (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 646)
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 1 draining session frameEnd events 2
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 2 draining session frameEnd events 1
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: SCF: Error Timeout: Sending critical error event for Session 1
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]:  (in src/api/Session.cpp, function sendErrorEvent(), line 1039)
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Sensor GUID 1 is in error state. Skipping requests, capture sequence ID = 3 continue draining session frameStart events 1
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: PowerServiceCore:handleRequests: timePassed = 4611
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: Module_id 30 Severity 2 : (fusa) Error: Timeout  propagating from:/capture/src/fusaViHandler.cpp 820
Mar 10 09:29:18 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 3 draining session frameEnd events 1
Mar 10 09:29:20 tegra-ubuntu nvargus-daemon[833]: SCF: Error Timeout:  (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function waitCompletion(), line 368)
Mar 10 09:29:20 tegra-ubuntu nvargus-daemon[833]: SCF: Error Timeout:  (propagating from src/services/capture/CaptureServiceDevice.cpp, function pause(), line 1069)
Mar 10 09:29:20 tegra-ubuntu nvargus-daemon[833]: SCF: Error Timeout: During capture abort, syncpoint wait timeout waiting for current frame to finish (in src/services/capture/CaptureServiceDevice.cpp, function handleCancelSourceRequests(), line 1164)
Mar 10 09:29:21 tegra-ubuntu nvargus-daemon[833]: SCF: Error Timeout:  (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function waitCompletion(), line 368)
Mar 10 09:29:21 tegra-ubuntu nvargus-daemon[833]: SCF: Error Timeout:  (propagating from src/services/capture/CaptureServiceDevice.cpp, function pause(), line 1069)
Mar 10 09:29:21 tegra-ubuntu nvargus-daemon[833]: SCF: Error Timeout: During capture abort, syncpoint wait timeout waiting for current frame to finish (in src/services/capture/CaptureServiceDevice.cpp, function handleCancelSourceRequests(), line 1164)
Mar 10 09:29:23 tegra-ubuntu nvargus-daemon[833]: SCF: Error Timeout:  (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function waitCompletion(), line 368)
Mar 10 09:29:23 tegra-ubuntu nvargus-daemon[833]: SCF: Error Timeout:  (propagating from src/services/capture/CaptureServiceDevice.cpp, function pause(), line 1069)
Mar 10 09:29:23 tegra-ubuntu nvargus-daemon[833]: SCF: Error Timeout: During capture abort, syncpoint wait timeout waiting for current frame to finish (in src/services/capture/CaptureServiceDevice.cpp, function handleCancelSourceRequests(), line 1164)
Mar 10 09:29:25 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 4 draining session frameStart events 1
Mar 10 09:29:25 tegra-ubuntu nvargus-daemon[833]:  (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 529)
Mar 10 09:29:25 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Sensor 1 already in same state
Mar 10 09:29:25 tegra-ubuntu nvargus-daemon[833]:  (in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
Mar 10 09:29:25 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter: CC has already been disposed (in src/components/CaptureContainerManager.cpp, function dispose(), line 161)
Mar 10 09:29:25 tegra-ubuntu nvargus-daemon[833]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 4 draining session frameEnd events 1
Mar 10 09:29:25 tegra-ubuntu nvargus-daemon[833]:  (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 646)
Mar 10 09:29:25 tegra-ubuntu nvargus-daemon[833]: Module_id 30 Severity 2 : (fusa) Error: Timeout  propagating from:/capture/src/fusaViHandler.cpp 820
Mar 10 09:29:25 tegra-ubuntu nvargus-daemon[833]: PowerServiceCore:handleRequests: timePassed = 6148
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: === gst-launch-1.0[2479]: CameraProvider destroyed (0xffffb0b01c60)=== gst-launch-1.0[2479]: Connection closed (FFFFB7D9B840)=== gst-launch-1.0[2479]: Connection cleaned up (FFFFB7D9B840)=== v4l2-ctl[2620]: Connection established (FFFFB7D9B840)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function verifyDeviceCaps(), line 206)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error ModuleNotPresent:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 66)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: ---- imager: No override file found. ----
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: initializeDevNode: Failed to open dev node '/dev/camera/video1'; No such file or directory, trying alternate default location
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error BadParameter: Control 10094858 not found (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findControlById(), line 1874)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error BadParameter:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function getControlRange(), line 331)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: initialize: focus query failed
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function open(), line 205)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 722)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 455)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 382)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function getSource(), line 554)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: initializeDevNode: Failed to open dev node '/dev/camera/video2'; No such file or directory, trying alternate default location
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error NotSupported: Must be capture/output devices (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function setActiveBufferType(), line 813)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error NotSupported:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 68)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: (NvOdmDevice) Error NotSupported:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorNonViCsi.cpp, function initialize(), line 146)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor_usb
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor_usb
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: NvPclStartPlatformDrivers: Failed to start module drivers
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: NvPclStateControllerOpen: Failed ImagerGUID 3. (error 0x2)
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: NvPclOpen: PCL Open Failed. Error: 0xf
Mar 10 09:31:11 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 725)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: === v4l2-ctl[2620]: CameraProvider initialized (0xffffb13b49f0)=== v4l2-ctl[2620]: CameraProvider destroyed (0xffffb13b49f0)=== v4l2-ctl[2620]: Connection closed (FFFFB7D9B840)=== v4l2-ctl[2620]: Connection cleaned up (FFFFB7D9B840)=== v4l2-ctl[2620]: Connection established (FFFFB7D9B840)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function verifyDeviceCaps(), line 206)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error ModuleNotPresent:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 66)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: ---- imager: No override file found. ----
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: initializeDevNode: Failed to open dev node '/dev/camera/video1'; No such file or directory, trying alternate default location
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error BadParameter: Control 10094858 not found (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findControlById(), line 1874)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error BadParameter:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function getControlRange(), line 331)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: initialize: focus query failed
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function open(), line 205)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 722)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 455)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 382)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function getSource(), line 554)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: initializeDevNode: Failed to open dev node '/dev/camera/video2'; No such file or directory, trying alternate default location
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error NotSupported: Must be capture/output devices (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function setActiveBufferType(), line 813)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: (NvCamV4l2) Error NotSupported:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 68)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: (NvOdmDevice) Error NotSupported:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorNonViCsi.cpp, function initialize(), line 146)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor_usb
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor_usb
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: NvPclStartPlatformDrivers: Failed to start module drivers
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: NvPclStateControllerOpen: Failed ImagerGUID 3. (error 0x2)
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: NvPclOpen: PCL Open Failed. Error: 0xf
Mar 10 09:31:12 tegra-ubuntu nvargus-daemon[833]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 725)
On Jetpack 6, RPi camera v2 is not enabled by default. Please exercute jetson-io.py to enable it, clean gstreamer cache and reboot.
exercute jetson-io.py to enable it, done, selected imx219-A
reboot, done
how to clean gstreamer cache?
Hi, I cleaned the cache, the error still exists.
Another weird thing is, all ota systems failed to read csi camera, but USB flash system works.
Even I replaced entire /usr/lib/aarch64-linux-gnu/nvidia folder with working one, it’s not working, does ota somehow missing updating some part of drivers?
Just found out that cam1 works, cam0 not working, how can I set cam0 to 2 lanes?
Please try the config Camera IMX219 Dual or Camera IMX219-C.
it turns out to be device tree problem, after configuring to 2 lanes everything works, thanks anyway.
