I’m using the following simple pipeline to get RGB frames and RTP timestamp:
rtspsrc location=RTSP_URL ! rtph264depay ! h264parse ! avdec_h264 ! videoconvert ! videorate ! video/x-raw,format=RGB,framerate=5/1 ! videoconvert ! autovideosink
This works and so using the Python bindings I set up a class with two probes, one to get the RTP timestamp from the rtph264depay
element and one at the last videoconvert
element to get RGB frames. I use a callback for the RGB frame like this:
def _frame_handler(instance: "GStreamerProbeStream", pad: Gst.Pad, info: Gst.PadProbeInfo, userdata: Any) -> Gst.PadProbeReturn:
buffer = info.get_buffer()
caps = pad.get_current_caps()
success, map_info = buffer.map(Gst.MapFlags.READ)
if not success:
return Gst.PadProbeReturn.DROP
rgb_frame = np.ndarray(
shape=(
caps.get_structure(0).get_value("height"),
caps.get_structure(0).get_value("width"),
3,
dtype=np.uint8,
buffer=map_info.data,
buffer.unmap(map_info)
if rgb_frame is None:
instance.frame = rgb_frame
return Gst.PadProbeReturn.OK
Replace the autovideosink
with a fakesink
and I use an async read on my self.frame
property to stream the frames over my next application. It runs smoothly, perhaps better than I expected.
When I try to port this code to JETSON TX2, I use similar logic with the following pipeline:
rtspsrc location=RTSP_URL ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! videorate ! 'video/x-raw(memory:NVMM),format=RGBA,framerate=5/1' ! nv3dsink
This pipeline works as well and so I try to use the same logic in Python again but the above callback does not work. The map_info.data
object is too small to construct a frame! I keep reading in these forums that this is a GPU memory type format and thus it is not the byte array that can create a complete frame. So I change my pipeline and omit (memory:NVMM)
rtspsrc location=RTSP_URL ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! videorate ! 'video/x-raw,format=RGBA,framerate=5/1' ! nv3dsink
Now I get RGBA frames and I change my callback like this:
shape=(
4,
dtype=np.uint8,
)[:,:,:3]
If I save this as an image, I get a correctly restructured image from my stream.
The problem is:
the video is way off. I’m talking around 30 seconds delay and it grows more and more, eating up my SWP memory at the same time, making the JETSON slower and slower until it crashes completely.
What is going on here? I’m wondering if I’ve set up something wrong but it is pretty straightforward. Does anybody have any type of hint on how to proceed with this?
