Gstreamer pipeline with nvarguscamerasrc 60 fps not achieved
We are developing a custom board based on xavier NX .In that I am trying to run the below mentioned gstreamer pipeline with sensor-mode=1 in nvarguscamera (corresponds to 60 fps).But I get only 30 fps from the verbose logs.
COMMAND:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 wbmode=0
aelock=true awblock=true sensor-mode=1 ! “video/x-raw” ! nvvidconv ! videoconv
ert ! queue ! fpsdisplaysink video-sink=xvimagesink --verbose
LOGS:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstXvImageSink:xvimagesink0: sync = true
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, f1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, format2
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)302
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, format=(s2
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)32
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV11
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
CAM: serial no file already exists, skips storing againCAM: serial no file already exists, skips storing againGST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 31.622776; Exposure Range min 450000, max ;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 31.622776; Exposure Range min 450000, max ;
GST_ARGUS: 1280 x 720 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 31.622776; Exposure Range min 450000, max 4;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 31.622776; Exposure Range min 450000, max 4;
GST_ARGUS: Running with following settings:
Camera index = 2
Camera mode = 0
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 17, dropped: 0, current: 321
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 17, dropped: 0, current: 32.91, average: 32.91
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 31, dropped: 1, fps: 27.77,8
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 31, dropped: 1, fps: 27.77, drop rate: 1.98
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 46, dropped: 1, current: 293
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 46, dropped: 1,
Whereas when I run the same using argus_camera , I get 60fps . The argus_camera I use is mentioned below.
COMMAND:
$ argus_camera --device=0 --sensormode=1 --verbose –
kpi
LOGS
Executing Argus Sample Application (argus_camera)
Argus Version: 0.97.3 (multi-process)
PerfTracker: app initial 5499 ms
PerfTracker 1: app intialized to task start 912 ms
PerfTracker 1: task start to issue capture 57 ms
PerfTracker 1: first request 550 ms
PerfTracker 1: total launch time 7020 ms
PerfTracker 1: frameRate 36.51 frames per second at 0 Seconds
PerfTracker 1: framedrop current request 0, total 0
PerfTracker 1: latency 30 ms average, min 26 max 37
PerfTracker 1: frameRate 60.12 frames per second at 0 Seconds
PerfTracker 1: latency 27 ms average, min 26 max 30
PerfTracker: display frame rate 58.93 frames per second
PerfTracker 1: frameRate 59.94 frames per second at 1 Seconds
Could anyone please suggest a fix for this issue.
Seems the sensor-mode option of nvarguscamerasrc fails in some cases. You may specify the mode in caps after it:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 wbmode=0 aelock=true awblock=true ! 'video/x-raw(memory:NVMM), width=1920, height=1080, framerate=60/1' ! nvvidconv ! queue ! fpsdisplaysink video-sink=xvimagesink --verbose
