You may need to develop your own plugin to convert the frame rate of stream(recalculate timestamp, insert new frames and dropping unnecessary frames). Current gstreamer and deepstream can not meet you requirement.
Related topics
| Deepstream rtmpsink Output smooth video stream | 6 | 1236 | October 12, 2021 | |
| How to set fps when reading rtsp stream in deepstream python? | 6 | 526 | June 25, 2023 | |
| Read rst gstreamer with nvidia acceleration | 3 | 516 | October 12, 2021 | |
| Output rtsp How to set the video framerate | 16 | 1192 | November 3, 2023 | |
| GPU accelerated reading from RTSP Stream | 13 | 8088 | October 12, 2021 | |
| Issue regarding deepstreamer-6.4 filesink output | 8 | 342 | April 30, 2024 | |
| RTSP streams working in deepstream, RTMP streams giving error: streaming stopped, reason not-linked (-1) | 41 | 153 | March 7, 2025 | |
| Multi-stream rtsp using Gstreamer in python code | 2 | 2845 | October 12, 2021 | |
| How to make rtsp stream with gstreamer commandline | 4 | 5231 | October 12, 2021 | |
| How to avoid a delay in RTP streaming | 4 | 2124 | October 12, 2021 |
