I am trying a to develop a G-streamer plugin, with multiple sinks and a single source. I will be feeding AVC encoded streams to each sinkpad of the plugin and I will do proprietary bit format conversion and will get a bit format stream from the single source pad of the plugin. Which Gstreamer filter class can be taken as my base class for development. Kindly help me with this.
Thanks Jachen.
Yes i will be getting multiple AVC stream through tee component as you specified.But,my goal is to create a plugin which can take those 3 AVC bit streams as input and do some proprietary bit format conversion and output the converted bit stream. can you please,help me with this?
