Gstreamer plugin without entire SDK
I have a connect X NIC and have Rivermax running, I noticed that the DeepStream SDK has various Gstreamer plugins, especially ones that can interface with Rivermax. Is there a way to use these Gstreamer plugins without necessarily incorporating the entire DeepStream SDK? From what I have read DeepStream requires either a dGPU or a Jetson device, is this correct? If so are there benefits with opting for one over the other?
Any clarification will help, Thank you!
No. DeepStream plugins rely on the DeepStream SDK.
Yes. The DeepStream components are all based on Nvidia hardware. DeepStream SDK supports dGPU and Jetson.
What do you mean? Do you want to compare Jetson and dGPU?
