GStreamer record multiple video with multiple audio
I have the following video inputs: 1 cam (hdmi2usb) and 1 screengrabber (hdmi2usb as well). These are present in /dev/videoN, as video0 and video1. I also have a usb microphone and the sound of the screengrabber (laptop).
I want to record 2 files, one with the cam+usb mike, and one with the laptop’s screen and sound.
I can record the two videos with this command:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! 'video/x-raw,width=640, height=480, framerate=30/1, format=YUY2' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! omxh264enc ! qtmux ! filesink location=polycom_video.mp4 v4l2src device=/dev/video1 ! 'video/x-raw,width=1920, height=1080, framerate=30/1, format=MJPG' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! omxh264enc ! qtmux ! filesink location=logitech_content.mp4 -e
I can record one with audio with this:
gst-launch-1.0 -v v4l2src device=/dev/video1 ! 'video/x-raw,width=1920,height=1080,framerate=30/1' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! omxh264enc ! queue ! mux. alsasrc ! audio/x-raw,width=16,depth=16,rate=44100,channel=1 ! queue ! audioconvert ! audioresample ! voaacenc ! aacparse ! qtmux name=mux ! filesink location=content_audiotest.mp4 sync=false -e
How can I achieve the goal mentioned earlier? How should I mux the audio with the video files properly?
Hi rapif,
You may want to check the following reply as reference: https://devtalk.nvidia.com/default/topic/1058494/jetson-agx-xavier/command-for-merging-audio-and-video-in-gstreamer/post/5368510/#5368510. In your case you probably need to replace audiotestsrc to read audio data from your usb mic, for example, you can use pulsesrc or alsasrc elements.
-Jafet
Hi Jafet,
Yes, my second code block is merging audio w/ video too, but I cannot make the double merge work.
If I’m correct the final command should look something like this:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! 'video/x-raw,width=640, height=480, framerate=30/1, format=YUY2' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! omxh264enc ! queue ! mux. alsasrc ! audio/x-raw,width=16,depth=16,rate=44100,channel=1 ! queue ! audioconvert ! audioresample ! voaacenc ! aacparse ! mux. ! qtmux name=mux ! filesink location=angekis_video.mp4 v4l2src device=/dev/video1 ! 'video/x-raw,width=1920,height=1080,framerate=30/1' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! omxh264enc ! queue ! mux2. alsasrc ! audio/x-raw,width=16,depth=16,rate=44100,channel=1 ! queue ! audioconvert ! audioresample ! voaacenc ! aacparse ! mux2. ! qtmux name=mux2 ! filesink location=logitech_content.mp4 sync=false -e
Although I’m having troubles with the two muxing. I think I cannot use 2 mux, therefore I need to use different names, hence mux2 with the second recording.
This code fails with syntax error. What am I missing here?
Do you guys have any advice on syncing the 2-2 pipes audio and video wise? How should I buffer them when it’s working?
Thanks in advance,
With debug, I get the following:
0:00:00.363509064 13164   0x55a5b75460 WARN                     omx gstomx.c:2826:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/support/.config:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
0:00:00.375105335 13164   0x55a5b75460 WARN                 default grammar.y:1137:priv_gst_parse_yyerror: Error during parsing: syntax error, unexpected LINK
0:00:00.375174972 13164   0x55a5b75460 ERROR           GST_PIPELINE grammar.y:1061:priv_gst_parse_yyparse: syntax error
0:00:00.375229869 13164   0x55a5b75460 ERROR           GST_PIPELINE grammar.y:1061:priv_gst_parse_yyparse: syntax error
0:00:00.380034704 13164   0x55a5b75460 WARN                 default grammar.y:1137:priv_gst_parse_yyerror: Error during parsing: syntax error, unexpected LINK
0:00:00.380096580 13164   0x55a5b75460 ERROR           GST_PIPELINE grammar.y:1061:priv_gst_parse_yyparse: syntax error
0:00:00.380137831 13164   0x55a5b75460 ERROR           GST_PIPELINE grammar.y:1061:priv_gst_parse_yyparse: syntax error
video0 is my usb cam, and video1 is my hdmi screen. So the problem is with my encoding formats.
For mapping the correct audio sources, I have the following information:
root@JetsonNano:~# cat /proc/asound/cards
 0 [tegrahda       ]: tegra-hda - tegra-hda
                      tegra-hda at 0x70038000 irq 83
 1 [tegrasndt210ref]: tegra-snd-t210r - tegra-snd-t210ref-mobile-rt565x
 2 [SpkUAC20       ]: USB-Audio - miniDSP VocalFusion Spk (UAC2.0
                      miniDSP miniDSP VocalFusion Spk (UAC2.0 at usb-70090000.xusb-2.4, high speed
 3 [Share          ]: USB-Audio - Logitech Screen Share
                      Alpha Imaging Tech. Corp. Logitech Screen Share at usb-70090000.xusb-1.2, super
So, I should use alsasrc device=hw:2, and alsasrc device=hw:3 correspondingly?
Can you please test these pipelines?
gst-launch-1.0 -e v4l2src device=/dev/video0 ! 'video/x-raw,width=640, height=480, framerate=30/1, format=YUY2' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! omxh264enc ! queue ! mp4mux name=mux ! filesink location="angekis_video.mp4" alsasrc ! audio/x-raw,width=16,depth=16,rate=44100,channel=1 ! queue ! audioconvert ! audioresample ! voaacenc ! aacparse ! mux.
gst-launch-1.0 -e v4l2src device=/dev/video1 ! 'video/x-raw,width=1920,height=1080,framerate=30/1' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! omxh264enc ! queue ! mp4mux name=mux2 ! filesink location="logitech_content.mp4" alsasrc ! audio/x-raw,width=16,depth=16,rate=44100,channel=1 ! queue ! audioconvert ! audioresample ! voaacenc ! aacparse ! mux2.
-Jafet
I’ve changed the camera to another with higher resolution, but the results were the same. The only section modified is the resolution.
I’m testing the video0 input with this:
gst-launch-1.0 -e v4l2src device=/dev/video0 ! 'video/x-raw,width=1920, height=1080, framerate=30/1, format=YUY2' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! omxh264enc ! queue ! mp4mux name=mux ! filesink location="angekis_video_sound.mp4" alsasrc ! audio/x-raw,width=16,depth=16,rate=44100,channel=1 ! queue ! audioconvert ! audioresample ! voaacenc ! aacparse ! mux.
So, about your pipelines, with the first one I can record, but get the following errors:
(gst-plugin-scanner:8930): GLib-GObject-WARNING **: 09:15:06.470: cannot register existing type 'GstInterpolationMethod'
(gst-plugin-scanner:8930): GLib-GObject-CRITICAL **: 09:15:06.470: g_param_spec_enum: assertion 'G_TYPE_IS_ENUM (enum_type)' failed
(gst-plugin-scanner:8930): GLib-GObject-CRITICAL **: 09:15:06.470: validate_pspec_to_install: assertion 'G_IS_PARAM_SPEC (pspec)' failed
Although it’s recording, but without audio, same as the second one.
It could be because of the wrong audio device selection, don’t you think?
Anyway, I feel this is a smaller problem, since my pipeline mentioned above is capable of recording audio and video. Though advices are welcomed on this matter too, of course.
The main question is merging the 2 pipelines together.
Hi rapif,
If I understand your use case correctly then you can run both pipelines (one for usb cam + mic and the other for the video capture device) in the same gst-launch command, for example, a pipeline like below is totally feasible:
gst-launch-1.0 -e videotestsrc is-live=true ! x264enc ! mp4mux name=mux ! filesink location="video_and_audio.mp4"  audiotestsrc ! lamemp3enc ! mux. videotestsrc is-live=true ! x264enc ! mp4mux name=mux2 ! filesink location="video_and_audio2.mp4"  audiotestsrc ! lamemp3enc ! mux2.
Although I recommend you first make sure both pipelines separately, its easier to debug. Then you can combine both pipelines in the same command by just putting one pipeline after the other.
