I am getting this SIGSEGV fault when I try to run a secondary model with nvinfer. I following a similar example to these slides: http://on-demand.gputechconf.com/gtc/2018/presentation/s81047-introduction-to-deep-stream-sdk.pdf
gst-launch-1.0 filesrc location=../../streams/sample_720p.mp4 ! decodebin ! nvinfer config-file-path=config_infer_resnet.txt ! queue ! nvtracker ! queue ! nvinfer config-file-path=sec_config_infer_resnet.txt ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)RGBA" ! queue ! nvosd ! nvvidconv ! "video/x-raw, format=(string)RGBA" ! videoconvert ! x264enc ! qtmux ! filesink location=out.mp4
Here is the file config_infer_resnet.txt
which is exactly the same as the file in the sample
# Copyright (c) 2018 NVIDIA Corporation. All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=../../models/Primary_Detector/resnet10.caffemodel
proto-file=../../models/Primary_Detector/resnet10.prototxt
model-cache=../../models/Primary_Detector/resnet10.caffemodel_b30_int8.cache
labelfile-path=../../models/Primary_Detector/labels.txt
int8-calib-file=../../models/Primary_Detector/cal_trt4.bin
#To use UFF models
#uff-file=<path to uff model>/<xyz>.uff
#input-dims=3;224;224;1 O=0(CHW) O=1(HWC)
net-stride=16
batch-size=30
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-classes=4
class-thresholds=0.2;0.2;0.2;0.2
class-eps=0.2;0.2;0.2;0.2
class-group-thresholds=1;1;1;1
roi-top-offset=0;0;0;0
roi-bottom-offset=0;0;0;0
detected-min-w=0;0;0;0
detected-min-h=0;0;0;0
detected-max-w=1280;1280;1280;1280
detected-max-h=720;720;720;720
interval=0
parser-bbox-norm=35.0;35.0
gie-unique-id=1
parse-func=4
output-bbox-name=conv2d_bbox
output-blob-names=conv2d_cov
#parse-bbox-func-name=parse_bbox_custom_resnet
#parse-bbox-lib-name=/path/to/this/directory/libnvparsebbox.so
Here is the file sec_config_infer_resnet.txt which is for the secondary model. I am using the sample models.
[property]
net-scale-factor=1
model-file=../../models/Secondary_VehicleTypes/resnet18.caffemodel
proto-file=../../models/Secondary_VehicleTypes/resnet18.prototxt
model-cache=../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_int8.cache
mean-file=../../models/Secondary_VehicleTypes/mean.ppm
labelfile-path=../../models/Secondary_VehicleTypes/labels.txt
int8-calib-file=../../models/Secondary_VehicleTypes/cal_trt4.bin
gpu-id=0
batch-size=16
num-classes=6
network-mode=1
detected-min-w=128
detected-min-h=128
detected-max-w=1280
detected-max-h=720
model-color-format=1
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
is-classifier=1
output-blob-names=predictions/Softmax
classifier-async-mode=1
classifier-threshold=0.51
This is the error that happens.
Setting pipeline to PAUSED ...
>>> Using Cached GIE model /media/HD1/ryans_workspace/driving_sample_video/DeepStream_Release/samples/configs/deepstream-app/../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_int8.cache crypto flags(0)
>>> Using Cached GIE model /media/HD1/ryans_workspace/driving_sample_video/DeepStream_Release/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_int8.cache crypto flags(0)
Pipeline is PREROLLING ...
Redistribute latency...
CUDA runtime error 77 cudaErrorIllegalAddress at line 116 in file cudaImage.cu
Caught SIGSEGV
CUDA runtime error 77 at line 800 in file gstnvvidconv.cpp
Is something wrong with my config file or is my gstreamer pipeline missing something?
