When I increase the framerate of a compressed gstreamer videotestsrc stream, the filesizes go down. I am on a TX1.
Pipeline:
gst-launch-1.0 videotestsrc ! 'video/x-raw, format=I420, width=1504,height=1504,is-live=true, framerate=120/1' ! omxh265enc control-rate=2 bitrate=40000000 ! 'video/x-h265, stream-format=(string)byte-stream' ! h265parse ! queue ! matroskamux ! filesink location=Documents/120.mp4 -e
<u>Filename Framerate Filesize CaptureTime</u>
30.mp4 30 fps 153.6 Mb 20.2 Sec
60.mp4 60 fps 89.3 Mb 20.1 Sec
90.mp4 90 fps 59.9 Mb 21.1 Sec
120.mp4 120 fps 43.9 Mb 20.0 Sec
Can someone help me understand why this is the case?
Please try
gst-launch-1.0 videotestsrc is-live=true ! 'video/x-raw, format=I420, width=1504,height=1504, framerate=120/1' ! omxh265enc control-rate=2 bitrate=40000000 ! 'video/x-h265, stream-format=(string)byte-stream' ! h265parse ! queue ! matroskamux ! filesink location=Documents/120.mp4 -e
Thanks for the suggestion. I didn’t realize the is-live cap could be placed outside the cap string. However, I got essentially the same result.
120.mp4 120 fps 44.3 Mb 20.2 Sec
Not sure if this is helpful, but the console output of the pipeline is below:
Setting pipeline to PAUSED ...
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingPipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
Framerate set to : 120 at NvxVideoEncoderSetParameterNew clock: GstSystemClock
NvMMLiteOpen : Block : BlockType = 8
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
===== NVENC blits (mode: 1) into block linear surfaces =====
Hi Dan_Goodrick,
Our test result looks good:
30.mp4 30 fps 86.9 MB 19 sec
60.mp4 60 fps 100.4 MB 19 sec
90.mp4 90 fps 100.4 MB 19 sec
120.mp4 120 fps 100.3 MB 19 sec
Test pipeline:
gst-launch-1.0 videotestsrc num-buffers=600 ! 'video/x-raw, format=I420, width=1504,height=1504,is-live=true, framerate=30/1' ! omxh265enc control-rate=2 bitrate=40000000 ! 'video/x-h265, stream-format=(string)byte-stream' ! h265parse ! queue ! matroskamux ! filesink location=Documents/30.mp4 -e
gst-launch-1.0 videotestsrc num-buffers=1200 ! 'video/x-raw, format=I420, width=1504,height=1504,is-live=true, framerate=60/1' ! omxh265enc control-rate=2 bitrate=40000000 ! 'video/x-h265, stream-format=(string)byte-stream' ! h265parse ! queue ! matroskamux ! filesink location=Documents/60.mp4 -e
gst-launch-1.0 videotestsrc num-buffers=1800 ! 'video/x-raw, format=I420, width=1504,height=1504,is-live=true, framerate=90/1' ! omxh265enc control-rate=2 bitrate=40000000 ! 'video/x-h265, stream-format=(string)byte-stream' ! h265parse ! queue ! matroskamux ! filesink location=Documents/90.mp4 -e
gst-launch-1.0 videotestsrc num-buffers=2400 ! 'video/x-raw, format=I420, width=1504,height=1504,is-live=true, framerate=120/1' ! omxh265enc control-rate=2 bitrate=40000000 ! 'video/x-h265, stream-format=(string)byte-stream' ! h265parse ! queue ! matroskamux ! filesink location=Documents/120.mp4 -e
Please try again with my test pipeline and update your result. Thanks!
I would expect the higher frame rate videos to be larger - but the 60, 90 and 120 fps captures are the same size.
The bitrate is 40M bits per second for all cases. If it is 30fps, each frame in average is 40M/30. If it is 120fps, each frame in average is 40M/120.
Of course - the bandwidth is getting saturated so the quality goes down. I should have realized that.
