I’m trying to modify https://github.com/dusty-nv/jetson-inference/ to run my network, and run inference on a video stream from either a file .mp4 or rtsp source.
I have successfully implemented my network and it’s working when used with images but I’m having troubles capturing the video stream and feeding it to my engine.
It’s not clear to me:
- which plugins in the Gstreamer pipeline I should use
- how to capture RGB frame instead of RGBA.
I’m using https://github.com/dusty-nv/jetson-inference/pull/93 to run the following pipelines:
- rtspsrc location=rtsp://user:pass@IP/media1.sdp protocols=udp latency=0 ! decodebin ! videoconvert ! appsink name=mysink
- filesrc location=test.mp4 ! decodebin ! nvvidconv ! video/x-raw, width=480, height=640 ! appsink name=mysink
I’m able to render the content of the stream on video using GlDisplay but when I try to run inference I never receive the output from my engine.
This is the output of an execution: https://pastebin.com/EUVnyX9P
What am i doing wrong?
