I’m streaming h265 video from the TX2 (R28.2) to a Ubuntu laptop. The network connection between TX2 and laptop is via a point-to-point wifi link. Received video looks great when the wifi signal strength is good, but when the signal strength is bad, the video is very pixelated and/or green. When the signal strength returns to good, the video quality improves to its prior good state.
I realize that a good connection is a very critical prerequisite here, but are there any suggestions on making the following pipelines as robust as possible? Goal is to get highest possible video quality within the available link bandwidth.
Sender (TX2):
gst-launch-1.0 nvcamerasrc fpsRange="30 30" intent=3 ! nvvidconv flip-method=6 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! omxh265enc control-rate=2 ! 'video/x-h265, stream-format=(string)byte-stream' ! h265parse ! rtph265pay mtu=1400 ! udpsink host=10.10.10.8 port=6554 sync=false async=false
Receiver (Ubuntu laptop):
gst-launch-1.0 udpsrc port=6554 ! application/x-rtp,encoding-name=H265,payload=96 ! rtpjitterbuffer mode=0 drop-on-latency=true latency=200 ! rtph265depay ! h265parse ! queue ! avdec_h265 ! xvimagesink sync=false async=false
