GStreamer warning: Cannot query video position:
I know there are many forum threads about this, but they’re all asking “what pipeline did you put in for GStreamer via cv2.VideoCapture()”? That doesn’t seem to be the relative question in my case…
Here is the most basic code to keep it simple. doesn’t matter what camera I use. still get the same error.
import cv2
print(cv2.version)
cam=cv2.VideoCapture(1) # logitec cams run 448X800 dispWXdispH
cam.set(cv2.CAP_PROP_FPS,30)
while True:
ret, frame=cam.read()
#print(frame.shape)
cv2.imshow(‘nanoCam’,frame)
cv2.moveWindow(‘nanoCam’,0,0)
if cv2.waitKey(1)==ord('q'):
    break
cam.release()
cv2.destroyAllWindows()
The full error is…
[ WARN:0] global/home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
anybody got any ideas??
• DeepStream Version
• TensorRT Version
What difference does that make? I get the error regardless of camera, Doesnt matter if I use my onboard IMX219-160, or if I’m using one of my Logitech pro stream C922x, If I use my jetson nano 4gb, jetpack 4.5 with code oss 1.32.3 with python3.9 interpreter and opencv 4.1, or my windows10 laptop with visual studio code, python 3.9 interpreter and opencv 4.5… the error is the same. So it’s gotta be deeper issue.
This has nothing to do with deepstream. This is opencv problem. opencv/cap_gstreamer.cpp at master · opencv/opencv · GitHub
