I’m working on a server where a python script analyzes an incoming video with AI, draws some boxes on it and returns the resulting video with gstreamer and opencv’s cv2.Videowriter() back to a rtsp-stream. The underlying docker-image was created 4 months ago and everything works like expected.
However, when I now rebuild the exact same docker image and run the same script again I get the following error message from Gstreamer:
[ WARN:0] global /var/local/git/opencv/modules/videoio/src/cap_gstreamer.cpp (1761) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module nvh264enc0 reported: Could not initialize supporting library.
[ WARN:0] global /var/local/git/opencv/modules/videoio/src/cap_gstreamer.cpp (1592) open OpenCV | GStreamer warning: GStreamer: cannot put pipeline to play
The pipeline looks like this:
"appsrc ! videoconvert ! nvh264enc ! h264parse ! rtph264pay name=pay0 config-interval=1 pt=96 ! udpsink host="+host+" port="+port+" sync=false "
The underlying relevant part of the dockerfile is basically installing CUDA, cudnn, Gstreamer and OPENCV, and as I said, the image from 4 months ago is still working, but not when I want to rebuild it:
FROM ubuntu:18.04
ENV DEBIAN_FRONTEND=noninteractive
RUN apt-get update -y
&& apt-get install -y
apt-utils
pkg-config
zlib1g-dev
libwebp-dev
libtbb2
libtbb-dev
libgtk2.0-dev
pkg-config
libavcodec-dev
libavformat-dev
libswscale-dev
libv4l-dev
cmake
autoconf
autotools-dev
build-essential
gcc
jq
wget
git
gtk-doc-tools
keyboard-configuration
software-properties-common
python3
python3-pip
python3-dev
&& pip3 install --upgrade pip
&& pip3 install numpy
RUN wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-ubuntu1804.pin
&& mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600
&& apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/7fa2af80.pub
&& add-apt-repository “deb Index of /compute/cuda/repos/ubuntu1804/x86_64 /”
&& apt-get update
&& wget http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64/nvidia-machine-learning-repo-ubuntu1804_1.0.0-1_amd64.deb
&& apt install ./nvidia-machine-learning-repo-ubuntu1804_1.0.0-1_amd64.deb
&& apt-get update
&& apt-get install -y cuda-11-4
&& apt-get install -y --allow-downgrades libcudnn8=8.2.2.26-1+cuda11.4
&& apt-get install -y libcudnn8-dev=8.2.2.26-1+cuda11.4
libgstreamer1.0-0
gstreamer1.0-plugins-base
gstreamer1.0-plugins-good
gstreamer1.0-plugins-bad
gstreamer1.0-plugins-ugly
gstreamer1.0-libav
gstreamer1.0-doc
gstreamer1.0-tools
libgstreamer1.0-dev
libgstreamer-plugins-base1.0-dev
&& git clone git://github.com/GStreamer/gst-plugins-bad /var/local/git/gst-plugins-bad
&& cd /var/local/git/gst-plugins-bad
&& git checkout 1.14.0
COPY Video_Codec_SDK_9.1.23/include /var/local/git/Video_Codec_SDK
RUN cd /var/local/git/Video_Codec_SDK
&& cp /usr/local/cuda/include/cuda.h /var/local/git/gst-plugins-bad/sys/nvenc/cuda.h
&& cp nvEncodeAPI.h /var/local/git/gst-plugins-bad/sys/nvenc
&& cp cuviddec.h /var/local/git/gst-plugins-bad/sys/nvdec
&& cp nvcuvid.h /var/local/git/gst-plugins-bad/sys/nvdec
&& NVENCODE_CFLAGS="-Icnvenc" ./autogen.sh --with-cuda-prefix="/usr/local/cuda" --disable-gtk-doc
&& cd /var/local/git/gst-plugins-bad/sys/nvenc
&& make
&& cp .libs/libgstnvenc.so /usr/lib/x86_64-linux-gnu/gstreamer-1.0/
&& cd /var/local/git/gst-plugins-bad/sys/nvdec
&& make
&& cp .libs/libgstnvdec.so /usr/lib/x86_64-linux-gnu/gstreamer-1.0/
ENV OPENCV_RELEASE_TAG=4.5.0
RUN git clone --depth 1 -b ${OPENCV_RELEASE_TAG} GitHub - opencv/opencv_contrib: Repository for OpenCV's extra modules /var/local/git/opencv_contrib
&& git clone --depth 1 -b ${OPENCV_RELEASE_TAG} GitHub - opencv/opencv: Open Source Computer Vision Library /var/local/git/opencv
&& cd /var/local/git/opencv
&& mkdir -p /var/local/git/opencv/build
&& cd /var/local/git/opencv/build $$
&& cmake -D CMAKE_INSTALL_PREFIX=/usr/local CMAKE_BUILD_TYPE=Release
-D INSTALL_PYTHON_EXAMPLES=ON
-D INSTALL_C_EXAMPLES=OFF
-D PYTHON_EXECUTABLE=$(which python3)
-D BUILD_opencv_python2=OFF
-D CMAKE_INSTALL_PREFIX=$(python3 -c “import sys; print(sys.prefix)”)
-D PYTHON3_EXECUTABLE=$(which python3)
-D PYTHON3_INCLUDE_DIR=$(python3 -c “from distutils.sysconfig import get_python_inc; print(get_python_inc())”)
-D PYTHON3_PACKAGES_PATH=$(python3 -c “from distutils.sysconfig import get_python_lib; print(get_python_lib())”)
-D WITH_GSTREAMER=ON
-D WITH_GSTREAMER_0_10=OFF
-D WITH_CUDA=ON
-D WITH_CUDNN=OFF
-D OPENCV_DNN_CUDA=OFF
-D BUILD_EXAMPLES=OFF
-D OPENCV_EXTRA_MODULES_PATH=/var/local/git/opencv_contrib/modules
-D WITH_TBB=ON
-D WITH_LIBV4L=OFF
-D WITH_FFMPEG=OFF
-D OPENCV_GENERATE_PKGCONFIG=ON …
&& make -j8 install
&& make install
&& ldconfig
The server is an ubuntu 18.04, has an intel CPU a nvidia Quadro P5000 GPU.
I am working on this problem for a few weeks now and just can’t find a solution for this. Every help is appreciated.
