**• AGX ( 32G )
**• DS5.1
**• Jetpack 4.5.1
**• TensorRT 7.1.3
**• Nvidia L4T 32.5.1
I would like to use gstreamer with the nv infer plugin , I have constructed the following pipeline
gst-launch-1.0 filesrc location= /opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! qtdemux ! h264parse ! nvv4l2decoder
! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvinfer config-file-path= /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt
batch-size=1 unique-id=1 ! nvtracker ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so
! nvinfer config-file-path= /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt batch-size=16 unique-id=2 infer-on-gie-id=1 infer-on-class-ids=2
! nvmultistreamtiler rows=1 columns=1 width=1920 height=1080 ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink
my deepstream-app config on tracker:
[tracker]
enable=0
tracker-width=640
tracker-height=384
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process and enable-past-frame applicable to DCF only
enable-batch-process=1
enable-past-frame=0
display-tracking-id=1
how I do constructed the similar pipeline in gstreamer ? if I remove the nvtracker the gst-launch won’t able to run .
