@ShaneCCC
I tested with set_mode_delay_ms=“1000”, no changes I can see.
This is the log of nvargus-daemon:
=== gst-launch-1.0[6489]: Connection established (7F83CB01D0)Thread 1 getting next capture
Thread 1 is waiting
Thread 2 getting next capture
Thread 2 is waiting
Thread 3 getting next capture
Thread 3 is waiting
Thread 4 getting next capture
Thread 4 is waiting
Thread 5 getting next capture
Thread 5 is waiting
Thread 6 getting next capture
Thread 6 is waiting
Thread 7 getting next capture
Thread 7 is waiting
Thread 8 getting next capture
Thread 8 is waiting
Thread 9 getting next capture
Thread 9 is waiting
Thread 10 getting next capture
Thread 10 is waiting
Thread 11 getting next capture
Thread 11 is waiting
Thread 12 getting next capture
Thread 12 is waiting
Starting services...
Worker thread IspHw statsComplete start
Worker thread IspHw frameComplete start
Worker thread CaptureScheduler checkFramePending start
Worker thread CaptureScheduler frameStart start
Worker thread V4L2CaptureScheduler checkCaptureComplete start
Worker thread V4L2CaptureScheduler issueCaptures start
Worker thread PS handleRequests start
getInstance: s_instance(0x7f7c77c290)
subscribe: SensorType(gyroscope)
subscribe: create SensorType(gyroscope) sensor(0x7f7c77d640)
subscribe: SensorType(accelerometer)
subscribe: create SensorType(accelerometer) sensor(0x7f7c77d7e0)
AC plugin not present: dlopen "acplugin.so", acplugin.so: cannot open shared object file: No such file or directory
Services are started
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
LSC: LSC surface is not based on full res!
=== gst-launch-1.0[6489]: CameraProvider initialized (0x7f7c82d220)sourceRegistry[0] assigned
ispRegistry[0] assigned
Using Source GUID 0
Worker thread ViCsiHw frameComplete start
Worker thread ViCsiHw frameStart start
Using ISP A
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=2, m_value=4294967295, m_timeout_ms=1000
No library found, disabling AC plugin.
Worker thread CaptureDispatcher start
Session::updatePerfHints()
updatePerfHints(): guid=0ll, CaptureIntent=1
updatePerfHints(): NvCameraCoreUseCase_Preview
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=1, m_value=30, m_timeout_ms=1000
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=15, m_value=0, m_timeout_ms=1000
No output buffers for 2
InstructionList:
+ GraphSettings
| SensorMode: 1944x1096 BayerS16GBRG 30.0fps
| output 0: 1944x1096 BL U8_V8_ER 420SP
| inputClipRect 0: (0.00,0.00, 1.00,1.00)
+ Instruction List
+ 0: CCDataSetupStage
| EstimatedIspOutLatencyFrames: 5
| NumConcurrentCaptures: 1
| UnprocessedYuvBufferMask: 0
+ 1: ACSynchronizeStage
+ 2: AeAfApplyStage
+ 3: AcPluginStage
| operation: opApply
+ 4: AcMergeStage
| IspIn: [1944, 1096]
| IspOut0: [1944, 1096]
| IspOut1: [0, 0]
| IspOut2: [0, 0]
+ 5: TempBufferAcquireStage
| Buffer Index: 2
| BufferRequirements: 1944x1 Pitch NonColor8
+ 6: TempBufferAcquireStage
| Buffer Index: 3
| BufferRequirements: 524288x1 Pitch NonColor8
+ 7: SensorISPCaptureStage
| Source GUID: 0
| Output A Buffer: 0
| SensorMetadata Buffer: 2
| Output IspStats Buffer: 3
+ 8: StatsBufferAcquireStage
| Buffer Index: 1
| BufferRequirements: 640x362 Pitch Y8_ER 420
+ 9: BlitStage
| Input Buffer: 0
| Output Buffer: 1
| Filter: Nearest
| Transform: None
| Src Rect: Not used
| Dst Rect: Not used
+ 10: StatsUpdateStage
| Output Meta Buffer: 2
+ 11: BufferReturnStage
| Output A Buffer: 2
+ 12: BufferReturnStage
| Output A Buffer: 3
+ 13: AcPluginStage
| operation: opAnalyze
+ 14: AfAnalysisStage
+ 15: MonitorStage
+ 16: ExifStage
+ 17: MakerNoteStage
+ 18: BufferReturnStage
| Output A Buffer: 0
+ 19: MetadataReturnStage
+ 20: PerfStatsStage
Created fiber 0x7f2c000b20 for CC 101 globalID 101 session 0
Thread 1 is working on CC 101 session 0 globalID 101 step 0
CC 101 session 0 completed step 0 in fiber 0x7f2c000b20
cc 101(1) session 0 runCount=0 runIspOut=0, latest ccId=0
CC 101 session 0 completed step 1 in fiber 0x7f2c000b20
NV AE and AfApply algorithms are active.
CC 101 session 0 completed step 2 in fiber 0x7f2c000b20
CC 101 session 0 completed step 3 in fiber 0x7f2c000b20
CC 101 session 0 completed step 4 in fiber 0x7f2c000b20
CC 101 session 0 completed step 5 in fiber 0x7f2c000b20
Created fiber 0x7f2c000dd0 for CC 102 globalID 102 session 0Session::updatePerfHints()
Thread 2 is working on CC 102 session 0 globalID 102 step 0
CC 102 session 0 completed step 0 in fiber 0x7f2c000dd0
cc 102(2) session 0 runCount=1 runIspOut=0, latest ccId=0
CC 102 session 0 completed step 1 in fiber 0x7f2c000dd0
CC 102 session 0 completed step 2 in fiber 0x7f2c000dd0
CC 102 session 0 completed step 3 in fiber 0x7f2c000dd0
CC 102 session 0 completed step 4 in fiber 0x7f2c000dd0
CC 102 session 0 completed step 5 in fiber 0x7f2c000dd0
CC 101 session 0 completed step 6 in fiber 0x7f2c000b20
CC 101 session 0 processing step 7 in fiber 0x7f2c000b20
FiberScheduler: cc 101, session 0, fiber 0x7f2c000b20 in progress...
Thread 1 is waiting
Thread 3 is waiting
CC 102 session 0 completed step 6 in fiber 0x7f2c000dd0
CC 102 session 0 processing step 7 in fiber 0x7f2c000dd0
FiberScheduler: cc 102, session 0, fiber 0x7f2c000dd0 in progress...
Thread 2 is waiting
Thread 4 is waiting
PowerServiceHw:addRequest: table size: before: 0, after:1
request table for ISP 0:
req[0]: output1 width=0, output1 height=0, output1 Bpp=0
req[0]: output2 width=0, output2 height=0, output2 Bpp=0
req[0]: input width=1944, input height=1096, input Bpp=12
req[0]: output width=130, output height=74, output Bpp=16
req[0]: input fps=30
req[0]: guID=0, stage type=SensorIspCapture
req[0]: clock=0 Hz, iso bw=54151 KB/s, non-iso bw=0 KB/s
req[450]: timeout=0
PowerServiceHwIsp:setLaBw: m_bwVal_Iso=54151 and m_bwVal_NonIso=0 KBpS
PowerServiceCore:setCameraBw: totalIsoBw=54151
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
Created fiber 0x7f2c000f70 for CC 103 globalID 103 session 0
Thread 5 is working on CC 103 session 0 globalID 103 step 0
Fiber 0x7f2c000f70 is aborting in CC 103 Session 0
FiberScheduler: cc 103 session 0, fiber 0x7f2c000f70 aborted
FiberScheduler: fiber 0x7f2c000f70 exiting
Thread 7 is waiting
Thread 5 is waiting
Thread 6 is waiting
PowerServiceHw:addRequest: table size: before: 1, after:2
req[388]: timeout=0
req[1]: output1 width=0, output1 height=0, output1 Bpp=0
req[1]: output2 width=0, output2 height=0, output2 Bpp=0
req[1]: input width=1944, input height=1096, input Bpp=12
req[1]: output width=1944, output height=1096, output Bpp=12
req[1]: input fps=30
req[1]: guID=0, stage type=SensorIspCapture
req[1]: clock=0 Hz, iso bw=595438 KB/s, non-iso bw=0 KB/s
req[450]: timeout=0
PowerServiceHw:updateRequests: table size: before: 2, after:2
req[385]: timeout=0
req[447]: timeout=0
PowerServiceHwIsp:setLaBw: m_bwVal_Iso=595438 and m_bwVal_NonIso=0 KBpS
PowerServiceCore:setCameraBw: totalIsoBw=595438
SCF: Error Timeout: ISP port 0 timed out! (in src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 478)
packet_write_wait:
attached the “dmesg -n 8” on serial with lot of log: start capture, freeze (around 240), watchdog, dump and finally reboot.
dmesg-gst-2k-long.txt (37.3 KB)
