Hi!
I’m trying to create a RSTP server using the Gstreamer Gst Python library in conda environment with the Jetson Xavier AGX, Jetpack 4.6, L4t 32.6.1, GStreamer 1.14.5, conda 23.1.0. It complains about the GstRtspServer that is not found.
File "/media/ubuntu/Advantec/s3ms_maestro_tensorrt/run.py", line 1, in <module>
from Maestro import Maestro
File "/media/ubuntu/Advantec/s3ms_maestro_tensorrt/Maestro.py", line 31, in <module>
from RtspStreamer import RTSP_Streamer
File "/media/ubuntu/Advantec/s3ms_maestro_tensorrt/RtspStreamer.py", line 17, in <module>
gi.require_version('GstRtspServer', '1.0')
File "/media/ubuntu/Advantec/miniconda3/envs/s3ms_jetson_env/lib/python3.9/site-packages/gi/__init__.py", line 126, in require_version
raise ValueError('Namespace %s not available' % namespace)
ValueError: Namespace GstRtspServer not available
The GStreamer RTSP Server is missing:
(s3ms_jetson_env) ubuntu@ubuntu:/media/ubuntu/Advantec/s3ms_maestro_tensorrt$ conda list | grep gst
gst-plugins-bad 1.22.0 h2f05ab0_0 conda-forge
gst-plugins-base 1.22.0 h8a62080_0 conda-forge
gst-plugins-good 1.22.0 hf363d5f_0 conda-forge
gst-plugins-ugly 1.22.0 h5356407_2 conda-forge
gstreamer 1.22.0 h1f26242_0 conda-forge
gstreamer-orc 0.4.33 h4e544f5_0 conda-forge
But how to do it in conda environment?
