GTX 1070 Ti driver for Solaris 11.4?
Are there any GTX 1070 Ti drivers for Solaris 11.4?
Sorry, I can’t help, but only want to say, “me, too”. I would like to know the answer to this.
The newer drivers from NVIDIA support the GTX 1070 Ti on Solaris. See my post above with the problems I had installing the latest drivers. I would recommend keeping the driver/graphics/nvidia package installed even though this may not be how it’s supposed to work. Just install the driver from the NVIDIA website and change permissions on /dev/nvidiactl and /dev/nvidia-modeset.
Are you sure the GTX 1070 Ti is supported? Have you tried it yourself? The reason I ask is because when I tried to install the driver, I got error messages as described here:
https://devtalk.nvidia.com/default/topic/1039210/solaris/solaris11-4-no-x11/
WARNING: Signature verification of module /kernel/drv/amd64/nvidia failed
WARNING: Signature verification of module /kernel/drv/amd64/nvidia_modeset failed
Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 387.34
nvidia_modeset: Unloading
krtld: WARNING: Signature verification of module /kernel/drv/amd64/nvidia failed
krtld: WARNING: Signature verification of module /kernel/drv/amd64/nvidia_modeset failed
nvidia_modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms
Did you get these error messages when you installed GTX 1070 Ti drivers?
I do not have a 1070 Ti myself, so all I can go on is the release notes that say support has been added. I also get the Signature verification messages as well, but my driver works fine. Have you tried running nvidia-smi to see if it lists the card?
Interesting! So you have the same error messages and still you got it to work. What steps did you take to make it work? If you tell me, I will verify it works, and I will write down all the commands you need to type, for future reference. I am sure people will thank me for that! :)
I have not tried nvidia-smi. I will very soon and report back. Thanx for your help! :)
Yes, the driver works fine even with those messages. See my other forum post “OpenGL doesnt work with 410.57 / Solaris 11.4” from a couple of weeks ago about how I had to setup permissions to make it work. That’s most likely your problem since the 1070 Ti should be supported in 387.34. The permissions will reset though if you ever have to do a reconfigure via /reconfigure file or -r kernel arg so just remember to set them back. I’m not sure who that really lies on to fix. I would think Nvidia could help since the Sun packaged drivers do not have this problem.
nvidia-smi should work regardless on a command line from anywhere and at least ID your card. If you can do that then it should be possible to make it work! :)
Ok, now I have installed Solaris 11.4 again.
# nvidia-smi
Failed to initialize NVML: Uknown Error
Hmmm… it seems I have another problem than you have? Do you have any clue of where to start digging?
When I boot Solaris 11.4, it says:
I have installed the driver with
# sh ./NVIDIA-Solaris-x86-387.34.run
# reboot -- -r
Hmmmm, do you happen to see anything like this in /var/adm/messages after the verification failed messages?
pcieb: [ID 586369 kern.notice] PCIE-device: display@0, nvidia0
npe: [ID 236367 kern.notice] PCI Express-device: display@0, nvidia0
genunix: [ID 936769 kern.notice] nvidia0 is /pci@2,0/pci8086,2f08@3/display@0
This is my messages in /var/adm/messages:
Oct 30 18:02:57 Solaris genunix: [ID 540533 kern.notice] SunOS Release 5.11 Version 11.4.0.15.0 64-bit
Oct 30 18:02:57 Solaris genunix: [ID 748049 kern.notice] Copyright (c) 1983, 2018, Oracle and/or its affiliates. All rights reserved.
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: lgpg
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: tsc
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: msr
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: mtrr
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: pge
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: de
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: cmov
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: mmx
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: mca
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: pae
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: cv8
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: pat
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: sep
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: sse
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: sse2
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: htt
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: asysc
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: nx
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: sse3
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: cx16
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: cmp
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: tscp
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: mwait
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: cpuid
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: ssse3
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: sse4_1
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: sse4_2
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: 1gpg
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: clfsh
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: 64
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: aes
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: pclmulqdq
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: xsave
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: avx
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: xsaveopt
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: rdrand
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: efs
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: avx2
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: smep
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: pcid
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: invpcid
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: ibrs
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: ibpb
Oct 30 18:02:57 Solaris unix: [ID 223955 kern.info] x86_feature: kpti_sw
Oct 30 18:02:57 Solaris unix: [ID 168242 kern.info] mem = 33485436K (0x7fbc9f000)
Oct 30 18:02:57 Solaris unix: [ID 190185 kern.info] SMBIOS v2.7 loaded (3308 bytes)
Oct 30 18:02:57 Solaris unix: [ID 972737 kern.info] Skipping psm: zvpsm
Oct 30 18:02:57 Solaris rootnex: [ID 466748 kern.info] root nexus = i86pc
Oct 30 18:02:57 Solaris rootnex: [ID 349649 kern.info] pseudo0 at root
Oct 30 18:02:57 Solaris genunix: [ID 936769 kern.info] pseudo0 is /pseudo
Oct 30 18:02:57 Solaris rootnex: [ID 349649 kern.info] scsi_vhci0 at root
Oct 30 18:02:57 Solaris genunix: [ID 936769 kern.info] scsi_vhci0 is /scsi_vhci
Oct 30 18:02:57 Solaris pci_autoconfig: [ID 139057 kern.info] NOTICE: reprogram io-range on ppb[0/1c/1]: 0x2000 ~ 0x2fff
Oct 30 18:02:57 Solaris pci_autoconfig: [ID 139057 kern.info] NOTICE: reprogram io-range on ppb[4/0/0]: 0x2000 ~ 0x2fff
Oct 30 18:02:57 Solaris pci_autoconfig: [ID 139057 kern.info] NOTICE: reprogram io-range on ppb[5/1/0]: 0x2000 ~ 0x2fff
Oct 30 18:02:57 Solaris apix: [ID 615120 kern.info] NOTICE: apic: local nmi: 255 0x5 1
Oct 30 18:02:57 Solaris genunix: [ID 958256 kern.info] Processing DMAR ACPI table
Oct 30 18:02:57 Solaris genunix: [ID 416442 kern.info] iommu0: Calculated pagetable levels = 4, hardware width = 48 bits, DVMA width = 39 bits, from MGAW (39) and SAGAW (0x4)
Oct 30 18:02:57 Solaris rootnex: [ID 349649 kern.info] npe0 at root: space 0 offset 0
Oct 30 18:02:57 Solaris genunix: [ID 936769 kern.info] npe0 is /pci@0,0
Oct 30 18:02:57 Solaris npe: [ID 236367 kern.info] PCI Express-device: isa@1f, isa0
Oct 30 18:02:58 Solaris kcf: [ID 787676 kern.info] NOTICE: kcf: FIPS-140 disabled.
Oct 30 18:02:58 Solaris pseudo: [ID 129642 kern.info] pseudo-device: acpippm0
Oct 30 18:02:58 Solaris genunix: [ID 936769 kern.info] acpippm0 is /pseudo/acpippm@0
Oct 30 18:02:58 Solaris pseudo: [ID 129642 kern.info] pseudo-device: ppm0
Oct 30 18:02:58 Solaris genunix: [ID 936769 kern.info] ppm0 is /pseudo/ppm@0
Oct 30 18:02:59 Solaris ahci: [ID 405770 kern.info] NOTICE: ahci0: hba AHCI version = 1.30
Oct 30 18:02:59 Solaris sata: [ID 663010 kern.info] /pci@0,0/pci15d9,818@1f,2 :
Oct 30 18:02:59 Solaris sata: [ID 761595 kern.info] 	SATA disk device at port 1
Oct 30 18:02:59 Solaris sata: [ID 846691 kern.info] 	model Samsung SSD 850 EVO 1TB
Oct 30 18:02:59 Solaris sata: [ID 693010 kern.info] 	firmware EMT01B6Q
Oct 30 18:02:59 Solaris sata: [ID 163988 kern.info] 	serial number S21DNCAGA02466B
Oct 30 18:02:59 Solaris sata: [ID 594940 kern.info] 	supported features:
Oct 30 18:02:59 Solaris sata: [ID 981177 kern.info] 	 48-bit LBA, DMA, Native Command Queueing, SMART, SMART self-test
Oct 30 18:02:59 Solaris sata: [ID 996592 kern.info] 	SATA Gen3 signaling speed (6.0Gbps)
Oct 30 18:02:59 Solaris sata: [ID 349649 kern.info] 	Supported queue depth 32
Oct 30 18:02:59 Solaris sata: [ID 349649 kern.info] 	capacity = 1953525168 sectors
Oct 30 18:02:59 Solaris scsi: [ID 583861 kern.info] sd0 at ahci0: target 1 lun 0
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] sd0 is /pci@0,0/pci15d9,818@1f,2/disk@1,0
Oct 30 18:02:59 Solaris genunix: [ID 408114 kern.info] /pci@0,0/pci15d9,818@1f,2/disk@1,0 (sd0) online
Oct 30 18:02:59 Solaris sata: [ID 761595 kern.info] 	SATA disk device at port 2
Oct 30 18:02:59 Solaris sata: [ID 846691 kern.info] 	model Samsung SSD 850 EVO 500GB
Oct 30 18:02:59 Solaris sata: [ID 693010 kern.info] 	firmware EMT03B6Q
Oct 30 18:02:59 Solaris sata: [ID 163988 kern.info] 	serial number S3R3NF0JA30954J
Oct 30 18:02:59 Solaris sata: [ID 349649 kern.info] 	capacity = 976773168 sectors
Oct 30 18:02:59 Solaris scsi: [ID 583861 kern.info] sd1 at ahci0: target 2 lun 0
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] sd1 is /pci@0,0/pci15d9,818@1f,2/disk@2,0
Oct 30 18:02:59 Solaris genunix: [ID 408114 kern.info] /pci@0,0/pci15d9,818@1f,2/disk@2,0 (sd1) online
Oct 30 18:02:59 Solaris sata: [ID 761595 kern.info] 	SATA disk device at port 3
Oct 30 18:02:59 Solaris sata: [ID 846691 kern.info] 	model KINGSTON SA400S37240G
Oct 30 18:02:59 Solaris sata: [ID 693010 kern.info] 	firmware SBFK61E1
Oct 30 18:02:59 Solaris sata: [ID 163988 kern.info] 	serial number 50026B77822E0DC0
Oct 30 18:02:59 Solaris sata: [ID 349649 kern.info] 	capacity = 468862128 sectors
Oct 30 18:02:59 Solaris scsi: [ID 583861 kern.info] sd2 at ahci0: target 3 lun 0
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] sd2 is /pci@0,0/pci15d9,818@1f,2/disk@3,0
Oct 30 18:02:59 Solaris genunix: [ID 408114 kern.info] /pci@0,0/pci15d9,818@1f,2/disk@3,0 (sd2) online
Oct 30 18:02:59 Solaris sata: [ID 761595 kern.info] 	SATA disk device at port 4
Oct 30 18:02:59 Solaris sata: [ID 846691 kern.info] 	model OCZ-VERTEX3
Oct 30 18:02:59 Solaris sata: [ID 693010 kern.info] 	firmware 2.25
Oct 30 18:02:59 Solaris sata: [ID 163988 kern.info] 	serial number OCZ-T42W3Z9M5ZY06HNH
Oct 30 18:02:59 Solaris scsi: [ID 583861 kern.info] sd3 at ahci0: target 4 lun 0
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] sd3 is /pci@0,0/pci15d9,818@1f,2/disk@4,0
Oct 30 18:02:59 Solaris genunix: [ID 408114 kern.info] /pci@0,0/pci15d9,818@1f,2/disk@4,0 (sd3) online
Oct 30 18:02:59 Solaris zfs: [ID 249136 kern.info] imported version 0 pool rpool using 44
Oct 30 18:02:59 Solaris genunix: [ID 308332 kern.info] root on rpool/ROOT/0_freshInstall fstype zfs
Oct 30 18:02:59 Solaris rootnex: [ID 349649 kern.info] acpinex0 at root
Oct 30 18:02:59 Solaris acpinex: [ID 328922 kern.info] acpinex: cpu@1, cpudrv0
Oct 30 18:02:59 Solaris genunix: [ID 408114 kern.info] /fw/cpu@1 (cpudrv0) online
Oct 30 18:02:59 Solaris krtld: [ID 402689 kern.info] NOTICE: Verified boot enabled; policy=warning
Oct 30 18:02:59 Solaris pseudo: [ID 129642 kern.info] pseudo-device: dld0
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] dld0 is /pseudo/dld@0
Oct 30 18:02:59 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci8086,c01@1, pcieb0
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] pcieb0 is /pci@0,0/pci8086,c01@1
Oct 30 18:02:59 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci8086,c09@1,2, pcieb1
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] pcieb1 is /pci@0,0/pci8086,c09@1,2
Oct 30 18:02:59 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci8086,8c10@1c, pcieb2
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] pcieb2 is /pci@0,0/pci8086,8c10@1c
Oct 30 18:02:59 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci8086,8c12@1c,1, pcieb3
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] pcieb3 is /pci@0,0/pci8086,8c12@1c,1
Oct 30 18:02:59 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci8086,8c16@1c,3, pcieb4
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] pcieb4 is /pci@0,0/pci8086,8c16@1c,3
Oct 30 18:02:59 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci8086,8c18@1c,4, pcieb5
Oct 30 18:02:59 Solaris genunix: [ID 936769 kern.info] pcieb5 is /pci@0,0/pci8086,8c18@1c,4
Oct 30 18:02:59 Solaris gfx_private: [ID 765636 kern.info] gfxp_fb: 800x600 - 32 bit framebuffer mapped at ffffa1000241f000
Oct 30 18:02:59 Solaris gfx_private: [ID 887945 kern.info] gfxp_fb: shadow framebuffer mapped at ffffa1c014c01000
Oct 30 18:02:59 Solaris gfx_private: [ID 519062 kern.info] gfxp_fb: using 7x14 fonts
Oct 30 18:03:01 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci15d9,818@1a, ehci0
Oct 30 18:03:01 Solaris genunix: [ID 936769 kern.info] ehci0 is /pci@0,0/pci15d9,818@1a
Oct 30 18:03:02 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci15d9,818@1d, ehci1
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] ehci1 is /pci@0,0/pci15d9,818@1d
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu0: x86 (chipid 0x0 GenuineIntel 306C3 family 6 model 60 step 3 clock 3392 MHz)
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu0: Intel(r) Xeon(r) CPU E3-1245 v3 @ 3.40GHz
Oct 30 18:03:02 Solaris pseudo: [ID 129642 kern.info] pseudo-device: hcad0
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] hcad0 is /pseudo/hcad@0
Oct 30 18:03:02 Solaris acpinex: [ID 328922 kern.info] acpinex: cpu@2, cpudrv1
Oct 30 18:03:02 Solaris genunix: [ID 408114 kern.info] /fw/cpu@2 (cpudrv1) online
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu1: x86 (chipid 0x0 GenuineIntel 306C3 family 6 model 60 step 3 clock 3392 MHz)
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu1: Intel(r) Xeon(r) CPU E3-1245 v3 @ 3.40GHz
Oct 30 18:03:02 Solaris unix: [ID 557947 kern.info] cpu1 initialization complete - online
Oct 30 18:03:02 Solaris acpinex: [ID 328922 kern.info] acpinex: cpu@3, cpudrv2
Oct 30 18:03:02 Solaris genunix: [ID 408114 kern.info] /fw/cpu@3 (cpudrv2) online
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu2: x86 (chipid 0x0 GenuineIntel 306C3 family 6 model 60 step 3 clock 3392 MHz)
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu2: Intel(r) Xeon(r) CPU E3-1245 v3 @ 3.40GHz
Oct 30 18:03:02 Solaris unix: [ID 557947 kern.info] cpu2 initialization complete - online
Oct 30 18:03:02 Solaris acpinex: [ID 328922 kern.info] acpinex: cpu@4, cpudrv3
Oct 30 18:03:02 Solaris genunix: [ID 408114 kern.info] /fw/cpu@4 (cpudrv3) online
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu3: x86 (chipid 0x0 GenuineIntel 306C3 family 6 model 60 step 3 clock 3392 MHz)
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu3: Intel(r) Xeon(r) CPU E3-1245 v3 @ 3.40GHz
Oct 30 18:03:02 Solaris unix: [ID 557947 kern.info] cpu3 initialization complete - online
Oct 30 18:03:02 Solaris pcieb: [ID 586369 kern.info] PCIE-device: pci10b5,8606@0, pcieb6
Oct 30 18:03:02 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci10b5,8606@0, pcieb6
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] pcieb6 is /pci@0,0/pci8086,8c12@1c,1/pci10b5,8606@0
Oct 30 18:03:02 Solaris pcieb: [ID 586369 kern.info] PCIE-device: pci10b5,8606@1, pcieb7
Oct 30 18:03:02 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci10b5,8606@1, pcieb7
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] pcieb7 is /pci@0,0/pci8086,8c12@1c,1/pci10b5,8606@0/pci10b5,8606@1
Oct 30 18:03:02 Solaris pcieb: [ID 586369 kern.info] PCIE-device: pci10b5,8606@4, pcieb8
Oct 30 18:03:02 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci10b5,8606@4, pcieb8
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] pcieb8 is /pci@0,0/pci8086,8c12@1c,1/pci10b5,8606@0/pci10b5,8606@4
Oct 30 18:03:02 Solaris pcieb: [ID 586369 kern.info] PCIE-device: pci10b5,8606@5, pcieb9
Oct 30 18:03:02 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci10b5,8606@5, pcieb9
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] pcieb9 is /pci@0,0/pci8086,8c12@1c,1/pci10b5,8606@0/pci10b5,8606@5
Oct 30 18:03:02 Solaris pcieb: [ID 586369 kern.info] PCIE-device: pci10b5,8606@7, pcieb10
Oct 30 18:03:02 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci10b5,8606@7, pcieb10
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] pcieb10 is /pci@0,0/pci8086,8c12@1c,1/pci10b5,8606@0/pci10b5,8606@7
Oct 30 18:03:02 Solaris pcieb: [ID 586369 kern.info] PCIE-device: pci10b5,8606@9, pcieb11
Oct 30 18:03:02 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci10b5,8606@9, pcieb11
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] pcieb11 is /pci@0,0/pci8086,8c12@1c,1/pci10b5,8606@0/pci10b5,8606@9
Oct 30 18:03:02 Solaris pcieb: [ID 586369 kern.info] PCIE-device: pci104c,823e@0, pcieb12
Oct 30 18:03:02 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci104c,823e@0, pcieb12
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] pcieb12 is /pci@0,0/pci8086,8c12@1c,1/pci10b5,8606@0/pci10b5,8606@9/pci104c,823e@0
Oct 30 18:03:02 Solaris pseudo: [ID 129642 kern.info] pseudo-device: tzmon0
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] tzmon0 is /pseudo/tzmon@0
Oct 30 18:03:02 Solaris acpinex: [ID 328922 kern.info] acpinex: cpu@5, cpudrv4
Oct 30 18:03:02 Solaris genunix: [ID 408114 kern.info] /fw/cpu@5 (cpudrv4) online
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu4: x86 (chipid 0x0 GenuineIntel 306C3 family 6 model 60 step 3 clock 3392 MHz)
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu4: Intel(r) Xeon(r) CPU E3-1245 v3 @ 3.40GHz
Oct 30 18:03:02 Solaris unix: [ID 557947 kern.info] cpu4 initialization complete - online
Oct 30 18:03:02 Solaris acpinex: [ID 328922 kern.info] acpinex: cpu@6, cpudrv5
Oct 30 18:03:02 Solaris genunix: [ID 408114 kern.info] /fw/cpu@6 (cpudrv5) online
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu5: x86 (chipid 0x0 GenuineIntel 306C3 family 6 model 60 step 3 clock 3392 MHz)
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu5: Intel(r) Xeon(r) CPU E3-1245 v3 @ 3.40GHz
Oct 30 18:03:02 Solaris unix: [ID 557947 kern.info] cpu5 initialization complete - online
Oct 30 18:03:02 Solaris acpinex: [ID 328922 kern.info] acpinex: cpu@7, cpudrv6
Oct 30 18:03:02 Solaris genunix: [ID 408114 kern.info] /fw/cpu@7 (cpudrv6) online
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu6: x86 (chipid 0x0 GenuineIntel 306C3 family 6 model 60 step 3 clock 3392 MHz)
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu6: Intel(r) Xeon(r) CPU E3-1245 v3 @ 3.40GHz
Oct 30 18:03:02 Solaris unix: [ID 557947 kern.info] cpu6 initialization complete - online
Oct 30 18:03:02 Solaris acpinex: [ID 328922 kern.info] acpinex: cpu@8, cpudrv7
Oct 30 18:03:02 Solaris genunix: [ID 408114 kern.info] /fw/cpu@8 (cpudrv7) online
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu7: x86 (chipid 0x0 GenuineIntel 306C3 family 6 model 60 step 3 clock 3392 MHz)
Oct 30 18:03:02 Solaris unix: [ID 950921 kern.info] cpu7: Intel(r) Xeon(r) CPU E3-1245 v3 @ 3.40GHz
Oct 30 18:03:02 Solaris unix: [ID 557947 kern.info] cpu7 initialization complete - online
Oct 30 18:03:02 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci15d9,818@14, xhci0
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] xhci0 is /pci@0,0/pci15d9,818@14
Oct 30 18:03:02 Solaris pcieb: [ID 586369 kern.info] PCIE-device: pci15d9,818@0, xhci1
Oct 30 18:03:02 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci15d9,818@0, xhci1
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] xhci1 is /pci@0,0/pci8086,8c12@1c,1/pci10b5,8606@0/pci10b5,8606@7/pci15d9,818@0
Oct 30 18:03:02 Solaris pseudo: [ID 129642 kern.info] pseudo-device: zfs0
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] zfs0 is /pseudo/zfs@0
Oct 30 18:03:02 Solaris usba: [ID 912658 kern.info] USB 2.0 device (usb8087,8008) operating at hi speed (USB 2.x) on USB 2.0 root hub: hub@1, hubd1 at bus address 2
Oct 30 18:03:02 Solaris genunix: [ID 936769 kern.info] hubd1 is /pci@0,0/pci15d9,818@1a/hub@1
Oct 30 18:03:02 Solaris genunix: [ID 408114 kern.info] /pci@0,0/pci15d9,818@1a/hub@1 (hubd1) online
Oct 30 18:03:03 Solaris usba: [ID 912658 kern.info] USB 2.0 device (usb8087,8000) operating at hi speed (USB 2.x) on USB 2.0 root hub: hub@1, hubd0 at bus address 2
Oct 30 18:03:03 Solaris genunix: [ID 936769 kern.info] hubd0 is /pci@0,0/pci15d9,818@1d/hub@1
Oct 30 18:03:03 Solaris genunix: [ID 408114 kern.info] /pci@0,0/pci15d9,818@1d/hub@1 (hubd0) online
Oct 30 18:03:03 Solaris usba: [ID 912658 kern.info] USB 1.10 device (usb45e,1e) operating at low speed (USB 1.x) on USB 2.0 root hub: mouse@1, hid2 at bus address 1
Oct 30 18:03:03 Solaris usba: [ID 349649 kern.info] 	Microsoft Microsoft IntelliMouse56 Explorer
Oct 30 18:03:03 Solaris genunix: [ID 936769 kern.info] hid2 is /pci@0,0/pci15d9,818@14/mouse@1
Oct 30 18:03:03 Solaris genunix: [ID 408114 kern.info] /pci@0,0/pci15d9,818@14/mouse@1 (hid2) online
Oct 30 18:03:03 Solaris usba: [ID 912658 kern.info] USB 2.0 device (usb430,100e) operating at full speed (USB 1.x) on USB 2.0 root hub: hub@2, hubd2 at bus address 2
Oct 30 18:03:03 Solaris genunix: [ID 936769 kern.info] hubd2 is /pci@0,0/pci15d9,818@14/hub@2
Oct 30 18:03:03 Solaris genunix: [ID 408114 kern.info] /pci@0,0/pci15d9,818@14/hub@2 (hubd2) online
Oct 30 18:03:04 Solaris usba: [ID 912658 kern.info] USB 2.0 device (usb430,a2) operating at full speed (USB 1.x) on USB 2.0 external hub: keyboard@4, hid1 at bus address 3
Oct 30 18:03:04 Solaris usba: [ID 349649 kern.info] 	Sun USB Keyboard
Oct 30 18:03:04 Solaris genunix: [ID 936769 kern.info] hid1 is /pci@0,0/pci15d9,818@14/hub@2/keyboard@4
Oct 30 18:03:04 Solaris genunix: [ID 408114 kern.info] /pci@0,0/pci15d9,818@14/hub@2/keyboard@4 (hid1) online
Oct 30 18:03:05 Solaris pseudo: [ID 129642 kern.info] pseudo-device: dtrace0
Oct 30 18:03:05 Solaris genunix: [ID 936769 kern.info] dtrace0 is /pseudo/dtrace@0
Oct 30 18:03:05 Solaris pseudo: [ID 129642 kern.info] pseudo-device: devinfo0
Oct 30 18:03:05 Solaris genunix: [ID 936769 kern.info] devinfo0 is /pseudo/devinfo@0
Oct 30 18:03:05 Solaris rootnex: [ID 349649 kern.info] fcoe0 at root
Oct 30 18:03:05 Solaris genunix: [ID 936769 kern.info] fcoe0 is /fcoe
Oct 30 18:03:05 Solaris rootnex: [ID 349649 kern.info] iscsi0 at root
Oct 30 18:03:05 Solaris genunix: [ID 936769 kern.info] iscsi0 is /iscsi
Oct 30 18:03:05 Solaris vga_arbiter: [ID 197929 kern.info] vga_arbiter: device added: PCI:0:1:0.0,decodes=io+mem+IO+MEM,owns=io+mem+IO+MEM,legalocks=none,normlocks=none
Oct 30 18:03:05 Solaris vga_arbiter: [ID 254375 kern.info] 1 vga device(s) found
Oct 30 18:03:05 Solaris rootnex: [ID 349649 kern.info] vga_arbiter0 at root
Oct 30 18:03:05 Solaris genunix: [ID 936769 kern.info] vga_arbiter0 is /vga_arbiter
Oct 30 18:03:05 Solaris rootnex: [ID 349649 kern.info] xsvc0 at root: space 0 offset 0
Oct 30 18:03:05 Solaris genunix: [ID 936769 kern.info] xsvc0 is /xsvc@0,0
Oct 30 18:03:05 Solaris pseudo: [ID 129642 kern.info] pseudo-device: pseudo1
Oct 30 18:03:05 Solaris genunix: [ID 936769 kern.info] pseudo1 is /pseudo/zconsnex@1
Oct 30 18:03:05 Solaris acpinex: [ID 328922 kern.info] acpinex: sb@0, acpinex1
Oct 30 18:03:05 Solaris pseudo: [ID 129642 kern.info] pseudo-device: biosdrv0
Oct 30 18:03:05 Solaris genunix: [ID 936769 kern.info] biosdrv0 is /pseudo/biosdrv@0
Oct 30 18:03:05 Solaris pseudo: [ID 129642 kern.info] pseudo-device: dcpc0
Oct 30 18:03:05 Solaris genunix: [ID 936769 kern.info] dcpc0 is /pseudo/dcpc@0
Oct 30 18:03:06 Solaris mac: [ID 469746 kern.info] NOTICE: e1000g0 registered
Oct 30 18:03:07 Solaris pseudo: [ID 129642 kern.info] pseudo-device: fasttrap0
Oct 30 18:03:07 Solaris genunix: [ID 936769 kern.info] fasttrap0 is /pseudo/fasttrap@0
Oct 30 18:03:07 Solaris pseudo: [ID 129642 kern.info] pseudo-device: fbt0
Oct 30 18:03:07 Solaris genunix: [ID 936769 kern.info] fbt0 is /pseudo/fbt@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: fcp0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] fcp0 is /pseudo/fcp@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: fcsm0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] fcsm0 is /pseudo/fcsm@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: llc10
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] llc10 is /pseudo/llc1@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: lockstat0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] lockstat0 is /pseudo/lockstat@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: lofi0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] lofi0 is /pseudo/lofi@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: power0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] power0 is /pseudo/power@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: profile0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] profile0 is /pseudo/profile@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: ramdisk1024
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] ramdisk1024 is /pseudo/ramdisk@1024
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: sbmc0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] sbmc0 is /pseudo/sbmc@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: sdt0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] sdt0 is /pseudo/sdt@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: smbclnt20
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] smbclnt20 is /pseudo/smbclnt2@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: srn0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] srn0 is /pseudo/srn@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: systrace0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] systrace0 is /pseudo/systrace@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: ucode0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] ucode0 is /pseudo/ucode@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: umac0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] umac0 is /pseudo/umac@0
Oct 30 18:03:08 Solaris pseudo: [ID 129642 kern.info] pseudo-device: uvfs0
Oct 30 18:03:08 Solaris genunix: [ID 936769 kern.info] uvfs0 is /pseudo/uvfs@0
Oct 30 18:03:09 Solaris krtld: [ID 711624 kern.warning] WARNING: Signature verification of module /kernel/drv/amd64/nvidia failed
Oct 30 18:03:12 Solaris pseudo: [ID 129642 kern.info] pseudo-device: nvidia255
Oct 30 18:03:12 Solaris genunix: [ID 936769 kern.info] nvidia255 is /pseudo/nvidia@255
Oct 30 18:03:12 Solaris krtld: [ID 711624 kern.warning] WARNING: Signature verification of module /kernel/drv/amd64/nvidia_modeset failed
Oct 30 18:03:12 Solaris nvidia_modeset: [ID 107833 kern.notice] Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  387.34  Tue Nov 21 03:40:22 PST 2017
Oct 30 18:03:12 Solaris pseudo: [ID 129642 kern.info] pseudo-device: bpf0
Oct 30 18:03:12 Solaris genunix: [ID 936769 kern.info] bpf0 is /pseudo/bpf@0
Oct 30 18:03:12 Solaris pseudo: [ID 129642 kern.info] pseudo-device: fssnap0
Oct 30 18:03:12 Solaris genunix: [ID 936769 kern.info] fssnap0 is /pseudo/fssnap@0
Oct 30 18:03:12 Solaris pseudo: [ID 129642 kern.info] pseudo-device: nsmb0
Oct 30 18:03:12 Solaris genunix: [ID 936769 kern.info] nsmb0 is /pseudo/nsmb@0
Oct 30 18:03:12 Solaris pseudo: [ID 129642 kern.info] pseudo-device: pm0
Oct 30 18:03:12 Solaris genunix: [ID 936769 kern.info] pm0 is /pseudo/pm@0
Oct 30 18:03:12 Solaris pseudo: [ID 129642 kern.info] pseudo-device: pool0
Oct 30 18:03:12 Solaris genunix: [ID 936769 kern.info] pool0 is /pseudo/pool@0
Oct 30 18:03:13 Solaris isa: [ID 202937 kern.info] ISA-device: asy0
Oct 30 18:03:13 Solaris genunix: [ID 936769 kern.info] asy0 is /pci@0,0/isa@1f/asy@1,3f8
Oct 30 18:03:13 Solaris ahci: [ID 405770 kern.info] NOTICE: ahci1: hba AHCI version = 1.20
Oct 30 18:03:13 Solaris isa: [ID 202937 kern.info] ISA-device: pit_beep0
Oct 30 18:03:13 Solaris genunix: [ID 936769 kern.info] pit_beep0 is /pci@0,0/isa@1f/pit_beep
Oct 30 18:03:13 Solaris mac: [ID 469746 kern.info] NOTICE: igb0 registered
Oct 30 18:03:23 Solaris pcieb: [ID 586369 kern.info] PCIE-device: pci1028,1f1c@0, mpt_sas0
Oct 30 18:03:23 Solaris npe: [ID 236367 kern.info] PCI Express-device: pci1028,1f1c@0, mpt_sas0
Oct 30 18:03:23 Solaris genunix: [ID 936769 kern.info] mpt_sas0 is /pci@0,0/pci8086,c09@1,2/pci1028,1f1c@0
Oct 30 18:03:52 Solaris genunix: [ID 227219 kern.info] This Solaris instance has UUID 8172f9b9-6b1b-4115-abdb-eeed09f06e69
Oct 30 18:03:52 Solaris genunix: [ID 892445 kern.info] dump device is /dev/zvol/dsk/rpool/dump size 15 GB (16350 MB)
Oct 30 18:03:54 Solaris mac: [ID 435574 kern.info] NOTICE: igb0 link up, 1000 Mbps, full duplex
Oct 30 18:03:56 Solaris /usr/sbin/dhcpagent[606]: [ID 778557 daemon.warning] configure_v4_lease: no IP broadcast specified for net1, making best guess
Oct 30 18:04:10 Solaris sendmail[916]: [ID 702911 mail.crit] My unqualified host name (KnubbeSolaris) unknown; sleeping for retry
Oct 30 18:04:12 Solaris asr-notify[1072]: [ID 610409 daemon.warning] System is not registered with Auto Service Request. Please register system using asradm(8) or visit http://www.oracle.com/asr for more information.
Oct 30 18:04:17 Solaris mac: [ID 736570 kern.info] NOTICE: e1000g0 unregistered
Oct 30 18:04:18 Solaris nvidia_modeset: [ID 107833 kern.notice] Unloading
Oct 30 18:04:19 Solaris mac: [ID 469746 kern.info] NOTICE: e1000g0 registered
Oct 30 18:05:10 Solaris sendmail[916]: [ID 702911 mail.alert] unable to qualify my own domain name (KnubbeSolaris) -- using short name
Oct 30 18:06:35 Solaris isa: [ID 202937 kern.info] ISA-device: asy0
Oct 30 18:06:35 Solaris genunix: [ID 936769 kern.info] asy0 is /pci@0,0/isa@1f/asy@1,3f8
Oct 30 18:06:35 Solaris scsi: [ID 583861 kern.info] sd1 at ahci0: target 2 lun 0
Oct 30 18:06:35 Solaris genunix: [ID 936769 kern.info] sd1 is /pci@0,0/pci15d9,818@1f,2/disk@2,0
Oct 30 18:06:35 Solaris scsi: [ID 583861 kern.info] sd2 at ahci0: target 3 lun 0
Oct 30 18:06:35 Solaris genunix: [ID 936769 kern.info] sd2 is /pci@0,0/pci15d9,818@1f,2/disk@3,0
Oct 30 18:06:35 Solaris scsi: [ID 583861 kern.info] sd3 at ahci0: target 4 lun 0
Oct 30 18:06:35 Solaris genunix: [ID 936769 kern.info] sd3 is /pci@0,0/pci15d9,818@1f,2/disk@4,0
Oct 30 18:06:35 Solaris pseudo: [ID 129642 kern.info] pseudo-device: ucode0
Oct 30 18:06:35 Solaris genunix: [ID 936769 kern.info] ucode0 is /pseudo/ucode@0
Oct 30 18:06:35 Solaris vga_arbiter: [ID 197929 kern.info] vga_arbiter: device added: PCI:0:1:0.0,decodes=io+mem+IO+MEM,owns=io+mem+IO+MEM,legalocks=none,normlocks=none
Oct 30 18:06:35 Solaris vga_arbiter: [ID 254375 kern.info] 1 vga device(s) found
Oct 30 18:06:35 Solaris rootnex: [ID 349649 kern.info] vga_arbiter0 at root
Oct 30 18:06:35 Solaris genunix: [ID 936769 kern.info] vga_arbiter0 is /vga_arbiter
Oct 30 18:06:35 Solaris rootnex: [ID 349649 kern.info] xsvc0 at root: space 0 offset 0
Oct 30 18:06:35 Solaris genunix: [ID 936769 kern.info] xsvc0 is /xsvc@0,0
Oct 30 18:06:35 Solaris krtld: [ID 711624 kern.warning] WARNING: Signature verification of module /kernel/drv/amd64/nvidia failed
Oct 30 18:06:35 Solaris pseudo: [ID 129642 kern.info] pseudo-device: biosdrv0
Oct 30 18:06:35 Solaris genunix: [ID 936769 kern.info] biosdrv0 is /pseudo/biosdrv@0
Oct 30 18:06:35 Solaris pseudo: [ID 129642 kern.info] pseudo-device: dcpc0
Oct 30 18:06:35 Solaris genunix: [ID 936769 kern.info] dcpc0 is /pseudo/dcpc@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: fbt0
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] fbt0 is /pseudo/fbt@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: fcp0
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] fcp0 is /pseudo/fcp@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: fcsm0
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] fcsm0 is /pseudo/fcsm@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: llc10
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] llc10 is /pseudo/llc1@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: lockstat0
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] lockstat0 is /pseudo/lockstat@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: lofi0
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] lofi0 is /pseudo/lofi@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: profile0
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] profile0 is /pseudo/profile@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: ramdisk1024
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] ramdisk1024 is /pseudo/ramdisk@1024
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: sbmc0
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] sbmc0 is /pseudo/sbmc@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: sdt0
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] sdt0 is /pseudo/sdt@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: srn0
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] srn0 is /pseudo/srn@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: systrace0
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] systrace0 is /pseudo/systrace@0
Oct 30 18:06:37 Solaris pseudo: [ID 129642 kern.info] pseudo-device: nvidia255
Oct 30 18:06:37 Solaris genunix: [ID 936769 kern.info] nvidia255 is /pseudo/nvidia@255
Oct 30 18:06:37 Solaris krtld: [ID 711624 kern.warning] WARNING: Signature verification of module /kernel/drv/amd64/nvidia_modeset failed
Oct 30 18:06:38 Solaris nvidia_modeset: [ID 107833 kern.notice] Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  387.34  Tue Nov 21 03:40:22 PST 2017
Oct 30 18:06:38 Solaris pseudo: [ID 129642 kern.info] pseudo-device: bpf0
Oct 30 18:06:38 Solaris genunix: [ID 936769 kern.info] bpf0 is /pseudo/bpf@0
Oct 30 18:06:38 Solaris pseudo: [ID 129642 kern.info] pseudo-device: fssnap0
Oct 30 18:06:38 Solaris genunix: [ID 936769 kern.info] fssnap0 is /pseudo/fssnap@0
Oct 30 18:06:38 Solaris pseudo: [ID 129642 kern.info] pseudo-device: nsmb0
Oct 30 18:06:38 Solaris genunix: [ID 936769 kern.info] nsmb0 is /pseudo/nsmb@0
Oct 30 18:06:38 Solaris pseudo: [ID 129642 kern.info] pseudo-device: pm0
Oct 30 18:06:38 Solaris genunix: [ID 936769 kern.info] pm0 is /pseudo/pm@0
Oct 30 18:06:51 Solaris zfs: [ID 249136 kern.info] imported version 28 pool SAMSUNG_500GB using 44
As you can see in the post above, my log file does not show anything like this.
Yes, it looks like it’s not actually seeing the card. :( While that driver you are using is supposed to support that card, the only suggestion I have right off hand would be to see if a newer version detects the card as that one is pretty old. You can go to https://www.nvidia.com/object/solaris-display-archive.html to get the latest versions.
It should certainly show up in nvidia-smi and /var/adm/messages even if it doesn’t work in X. You may also want to see if prtdiag will work on your system. Run prtdiag -v and see if it shows up in a populated PCIe slot.
I apologize, when I looked at the drivers in more detail it appears the later ones do not support anything but the quadro cards. I thought they were all a unified driver. I’ll see if I can find anything else.
You may also want to run a scanpci. For instance I get this:
scanpci|grep -i nvidia
NVIDIA Corporation GK107 [NVS 510]
NVIDIA Corporation GK107 HDMI Audio Controller
Hmmmm… Weird. I did as you suggested, and I see the card.
# scanpci
pci bus 0x0001 cardnum 0x00 function 0x00: vendor 0x10de device 0x1b82
 NVIDIA Corporation GP104 [GeForce GTX 1070 Ti]
pci bus 0x0001 cardnum 0x00 function 0x01: vendor 0x10de device 0x10f0
 NVIDIA Corporation GP104 High Definition Audio Controller
Also, I see this:
# prtdiag
==== Upgradeable Slots ====================================
ID  Status    Type             Description
0   available PCI Express      PCH_SLOT1 PCI-E 2.0 X1 (INX4)
1   in use    PCI Express      CPU_SLOT2 PCI-E 3.0 X4 (IN X16)
2   available PCI Express      PCH_SLOT3 PCI-E 2.0 X1 (INX4)
3   available PCI Express      CPU_SLOT4 PCI-E 3.0 X8 (IN X16)
4   available PCI Express      PCH_SLOT5 PCI-E 2.0 X1 (INX4)
5   in use    PCI Express      CPU_SLOT6 PCI-E 3.0 X16
So, yes the card is recognized. But, nvidia driver does not work.
