Last night my laptop’s graphics driver stopped working and I can’t figure out why.
I am running Ubuntu 22.04 LTS, and I was using the nvidia-driver-525 package at the time. Upon reboot however, my laptop would freeze before graphics mode started (I had a black screen with a grey cursor in the top left corner that stopped blinking after a few seconds, and then froze). I was able to enter tty mode and could use prime-select to fall back to my integrated GPU, so I can still access my system relatively normally.
I had a similar issue a few months ago when I tried installing some GPU libraries (I think it was tensorflow) and I might have accidentally broken something at the time. Back then I also fell back to my iGPU for a week or so but after reinstalling the nvidia drivers from scratch my system worked normally again.
Based on similar issues I could find via googling and my own past experience, I have tried purging all nvidia packages and installing nvidia-driver-515 (yes, that is an earlier version from what I was using before, I am aware and that was on purpose) from scratch, but that does not seem to work and the situation remains the same.
If anyone can help me figure out (mostly where to look for the issue), I could gladly use any help!
Attached is my nvidia bug report log. Based on some similar threads (that did not solve my problem) I can also provide:
~$ dkms status
nvidia/515.65.01, 5.15.0-57-generic, x86_64: installed
~$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
During boot, the splash text warned it could not (among others) launch the nvidia persistence daemon. Sysctl does not give me meaningful information, but for the record:
~$ sudo systemctl status nvidia-persistenced.service
× nvidia-persistenced.service - NVIDIA Persistence Daemon
Loaded: loaded (/lib/systemd/system/nvidia-persistenced.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2023-01-07 12:13:08 CET; 15min ago
Process: 990 ExecStart=/usr/bin/nvidia-persistenced --verbose (code=exited, status=1/FAILURE)
Process: 994 ExecStopPost=/bin/rm -rf /var/run/nvidia-persistenced/* (code=exited, status=0/SUCCESS)
CPU: 5ms
Jan 07 12:13:08 ***** systemd[1]: nvidia-persistenced.service: Scheduled restart job, restart counter is at 5.
Jan 07 12:13:08 ***** systemd[1]: Stopped NVIDIA Persistence Daemon.
Jan 07 12:13:08 ***** systemd[1]: nvidia-persistenced.service: Start request repeated too quickly.
Jan 07 12:13:08 ***** systemd[1]: nvidia-persistenced.service: Failed with result 'exit-code'.
Jan 07 12:13:08 ***** systemd[1]: Failed to start NVIDIA Persistence Daemon.
If I can provide more information, I’d be happy to do so! Any suggestions or pointers are appreciated.
nvidia-bug-report.log.gz (150.2 KB)
