Hello!
I’m experiencing weird behavior regarding shared variables. I’m writing a tessellation shader for nurbs surfaces, however some of the shared variables don’t get written:
shared vec4 CoeffsU[52];
shared vec4 CoeffsV[52];
shared float Blossom[64];
if( gl_LocalInvocationID == 0 )
FillCoeffTable(CoeffsU, degreeU, numControlPointsU, numknotsU, knotsU);
if( gl_LocalInvocationID == 1 )
FillCoeffTable(CoeffsV, degreeV, numControlPointsV, numknotsV, knotsV);
barrier();
// NURBS calculation, CoeffsV is garbage
for( ... )
for( ... )
index1 = spanU * MAX_ORDER + k;
index2 = spanV * MAX_ORDER + l;
nom = dot(CoeffsU[index1], polyU) * dot(CoeffsV[index2], polyV);
nom = nom * weightsU[cpU] * weightsV[cpV] * denom;
pos += ...;
If I use CoeffsU in place of CoeffsV, then it’s “ok”.
If I swap the declaration order of CoeffsU and CoeffsV, then CoeffsU becomes garbage and CoeffsV gets valid (which means the input parameters are correct).
What might cause this? As I understand shared memory should be at least 32 KB, and I’m using just 2…
ps.: I can give compilable code later, if needed.
Tried the following:
barrier();
for( int i = 0; i < 52; ++i )
CoeffsV[i] = CoeffsU[i];
barrier();
No effect.
Now another interesting bug (assuming I removed CoeffsV, and using CoeffsU only):
//shared vec4 CoeffsV[52]; // removed, using CoeffsU instead
As I mentioned this case is “ok”. Now swap the declaration order of CoeffsU and Blossom → CoeffsU becomes garbage.
Finally I was able to make it work… I found out the following things (1):
void FillCoeffTable(vec4 coeffs[52], int degree, int numcvs, int numknots, float knots[MAX_KNOTS])
FUNCTION COMPILATION DOESN’T WORK! I expanded this function inline (in place of calling), and the swap bug mentioned above disappeared.
Now I hoped that this would fix the original bug too (with CoeffsV being garbage), but no. This is also an error (2):
// calculate CoeffsU inline
// calculate CoeffsV inline
Doesn’t work!! The correct solution is now:
// WORKING
This is very very sad…
