Configuration: SuSE 13.2 3.16.6-2-desktop x86_64
blacklisted nouveau
installed via bash NVIDIA-Linux-x86_64-346.16.run, let the script install new xorg.conf.
The installer warns me that it doesn’t support the card even though this is the 970M which the
beta driver is supposed to address.
lspci -nvv:
01:00.0 0300: 10de:13d8 (rev a1) (prog-if 00 [VGA controller])
Subsystem: 1462:112d
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 16
Region 0: Memory at f6000000 (32-bit, non-prefetchable)
Region 1: Memory at e0000000 (64-bit, prefetchable)
Region 3: Memory at f0000000 (64-bit, prefetchable)
Region 5: I/O ports at e000
Expansion ROM at f7000000 [disabled]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [78] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag+ PhantFunc- AuxPwr- NoSnoop+
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <1us, L1 <4us
ClockPM+ Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Via message
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [250 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [258 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=255us PortTPowerOnTime=10us
Capabilities: [128 v1] Power Budgeting <?>
Capabilities: [420 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900 v1] #19
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia
after reboot:
lsmod
nvidia 8430689 0
i2c_algo_bit 13413 1 i915
drm_kms_helper 65670 1 i915
drm 335594 4 i915,drm_kms_helper,nvidia
xhci_hcd 178893 0
wmi 19193 2 msi_wmi,mxm_wmi
video 24419 1 i915
button 13971 1 i915
bbswitch 13943 0
and after a startx:
Xorg.0.log
X.Org X Server 1.16.1
Release Date: 2014-09-21
[ 70.256] X Protocol Version 11, Revision 0
[ 70.256] Build Operating System: openSUSE SUSE LINUX
[ 70.256] Current Operating System: Linux wwcverix2.site 3.16.6-2-desktop #1 SMP PREEMPT Mon Oct 20 13:47:22 UTC 2014 (feb42ea) x86_64
[ 70.256] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.6-2-desktop root=UUID=7a2631ab-724d-43a4-a11c-f8bcdc99c85b resume=/dev/sda1 splash=silent quiet showopts nomodeset 3
[ 70.256] Build Date: 08 October 2014 05:49:10PM
[ 70.256]
[ 70.256] Current version of pixman: 0.32.6
[ 70.256] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 70.256] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 70.256] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Nov 21 13:29:37 2014
[ 70.257] (==) Using config file: "/etc/X11/xorg.conf"
[ 70.257] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 70.257] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 70.257] (==) ServerLayout "Layout0"
[ 70.257] (**) |-->Screen "Screen0" (0)
[ 70.257] (**) | |-->Monitor "Monitor0"
[ 70.257] (**) | |-->Device "Device0"
[ 70.257] (**) |-->Input Device "Keyboard0"
[ 70.257] (**) |-->Input Device "Mouse0"
[ 70.257] (==) Automatically adding devices
[ 70.257] (==) Automatically enabling devices
[ 70.257] (==) Automatically adding GPU devices
[ 70.261] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
[ 70.261] Entry deleted from font path.
[ 70.261] (==) FontPath set to:
/usr/share/fonts/misc:unscaled,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi:unscaled,
/usr/share/fonts/75dpi:unscaled,
/usr/share/fonts/ghostscript/,
/usr/share/fonts/cyrillic:unscaled,
/usr/share/fonts/truetype/,
built-ins
[ 70.261] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 70.261] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 70.261] (WW) Disabling Keyboard0
[ 70.261] (WW) Disabling Mouse0
[ 70.261] (II) Loader magic: 0x80dc60
[ 70.261] (II) Module ABI versions:
[ 70.261] X.Org ANSI C Emulation: 0.4
[ 70.261] X.Org Video Driver: 18.0
[ 70.261] X.Org XInput driver : 21.0
[ 70.261] X.Org Server Extension : 8.0
[ 70.261] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 70.262] (--) PCI:*(0:0:2:0) 8086:0416:1462:112d rev 6, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64
[ 70.262] (--) PCI: (0:1:0:0) 10de:13d8:1462:112d rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 70.262] (II) LoadModule: "glx"
[ 70.262] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 70.351] (II) Module glx: vendor="NVIDIA Corporation"
[ 70.351] compiled for 4.0.2, module version = 1.0.0
[ 70.351] Module class: X.Org Server Extension
[ 70.351] (II) NVIDIA GLX Module 346.16 Fri Nov 7 16:24:03 PST 2014
[ 70.355] (II) LoadModule: "nvidia"
[ 70.355] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 70.371] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 70.371] compiled for 4.0.2, module version = 1.0.0
[ 70.371] Module class: X.Org Video Driver
[ 70.371] (II) NVIDIA dlloader X Driver 346.16 Fri Nov 7 15:59:29 PST 2014
[ 70.371] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 70.371] (--) using VT number 2
[ 70.486] (EE) No devices detected.
[ 70.486] (EE)
Fatal server error:
[ 70.486] (EE) no screens found(EE)
[ 70.486] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 70.486] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 70.486] (EE)
How can I debug this further?
nvidia-bug-report.log.gz (77.7 KB)
nvidia-installer.log (248 KB)
