Hi
I got PNY 1080Ti , with 3xDP and 1xHDMI
HDMI output works ok in Windows and Centos7.2. But DP outputs doesnt works/recognize any display in win10 and centos. Cables checked/working on another card (1070).
runs DP output updater, after that lower (4) DP port begins show boot process in linux text mode. But after start X11 no displays connected to DP detected.
Driver 430.40
xrandr
Screen 0: minimum 8 x 8, current 1920 x 1200, maximum 32767 x 32767
HDMI-0 connected primary 1920x1200+0+0 (normal left inverted right x axis y axis) 519mm x 324mm
1920x1200 59.95*+
1680x1050 59.95
1600x1200 60.00
1440x900 74.98 59.89
1280x1024 75.02
1280x960 60.00
1280x720 60.00
1152x864 60.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
640x480 75.00 72.81 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
