Hi, this is actually a re-post of an original post I’ve written on the GeForce forums. I’ve been told to come here: https://forums.geforce.com/default/topic/820047/geforce-700-600-series/gtx760-cuda-issue-quot-error-only-0-devices-available-1-requested-quot-/
I’ve run the ‘nvidia-bug-report.sh’ and it reads:"
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 18811463
Date: Sat Mar 28 21:34:10 CET 2015
uname: Linux filouarch 3.19.2-1-ARCH #1 SMP PREEMPT Wed Mar 18 16:21:02 CET 2015 x86_64 GNU/Linux
command line flags:
The following was posted on 03/20/2015 03:53 PM
I’m trying to run a code similar to the nbody NVidia’s example. I’m getting the error “Error: only 0 Devices available, 1 requested. Exiting.”, which causes a seg fault.
The output of the execution:
./nbody Clouda_config.conf
is
Start time :
Fri Mar 20 16:38:30 CET 2015
myReal = double
dt = 1.00e-03 us | p = 1.00 pa | T_BG = 297.0 K | harmo_lmax = 12
recordTimeAfterThermalization = 600000000.00 s | thermTime = 0.00e+00 us
nbody.cpp::showHelp() empty for now.
*** Break *** segmentation violation
There was a crash.
This is the entire stack trace of all threads:
#0 0x00007f7093025aaa in waitpid () from /usr/lib/libc.so.6
#1 0x00007f7092fad40b in do_system () from /usr/lib/libc.so.6
#2 0x00007f709b9be654 in TUnixSystem::StackTrace() () from /usr/lib/root/libCore.so.5.34
#3 0x00007f709b9c074c in TUnixSystem::DispatchSignals(ESignals) () from /usr/lib/root/libCore.so.5.34
#4
#5 0x00007f7092ffe61b in __memcpy_sse2_unaligned () from /usr/lib/libc.so.6
#6 0x00007f709b97cbed in ROOT::TGenericClassInfo::CreateRuleSet(std::vector<ROOT::TSchemaHelper, std::allocatorROOT::TSchemaHelper >&, bool) () from /usr/lib/root/libCore.so.5.34
#7 0x00007f709b97d055 in ROOT::TGenericClassInfo::GetClass() () from /usr/lib/root/libCore.so.5.34
#8 0x00007f70990b4f5a in TTree::Class() () from /usr/lib/root/libTree.so.5.34
#9 0x00007f709b9394bd in TObject::InheritsFrom(TClass const*) const () from /usr/lib/root/libCore.so.5.34
#10 0x00007f709a9fde0a in TDirectoryFile::Save() () from /usr/lib/root/libRIO.so.5.34
#11 0x00007f709a9fc068 in TDirectoryFile::Close(char const*) () from /usr/lib/root/libRIO.so.5.34
#12 0x00007f709a9f2bf4 in TFile::Close(char const*) () from /usr/lib/root/libRIO.so.5.34
#13 0x00007f709b903108 in ?? () from /usr/lib/root/libCore.so.5.34
#14 0x00007f709b90360a in TROOT::CloseFiles() () from /usr/lib/root/libCore.so.5.34
#15 0x00007f7092fa414f in __cxa_finalize () from /usr/lib/libc.so.6
#16 0x00007f709b8deaa3 in ?? () from /usr/lib/root/libCore.so.5.34
#17 0x00007fff7312c2f0 in ?? ()
#18 0x00007f709c0a57f7 in _dl_fini () from /lib64/ld-linux-x86-64.so.2
The lines below might hint at the cause of the crash.
If they do not help you then please submit a bug report at
Sign in to GitHub · GitHub. Please post the ENTIRE stack trace
from above as an attachment in addition to anything else
that might help us fixing this issue.
Hardware:
CPU is I7-2600K
Video card is MSI GTX 760 driver 304.125
OS is Arch Linux: 3.18.6-1-ARCH
GCC version is 4.9.2 20150304 (prerelease)
root version 5.34/24
nvcc is version release 6.5, V6.5.16
I’m using KDE Version 4.14.6
I’ve already posted on [SOLVED] NVidia/CUDA error : "0 Devices available" / Kernel & Hardware / Arch Linux Forums
What I don’t get is that the deviceID is set to 0 explicitly in the code. Maybe I got a file or link missing ?
Any help would be appreciated !
Madsub
