GUI Screen Issues on Rocky Linux 9.4 with NVIDIA Driver Installation
On Rocky Linux 9.4, there is an issue where the GUI screen does not appear after installing the NVIDIA driver. The server is equipped with four PCIE type A100 GPUs.
The driver version is 555.42.06, and the installation method is as follows:
sudo dnf install kernel-devel-$(uname -r) kernel-headers-$(uname -r)
sudo rpm --install cuda-repo-rhel9-12-5-local-12.5.1_555.42.06-1.x86_64.rpm
sudo dnf module install nvidia-driver:latest-dkms
Edit the following file:
sudo vim /etc/modprobe.d/blacklist-nouveau.conf
blacklist nouveau
options nouveau modeset=0
Then, run:
sudo dracut --force
sudo reboot
After rebooting, the screen remains black after boot. However, switching to CLI mode using ctrl + alt + F2 on the KVM provides a functional CLI screen. Running nvidia-smi indicates that the GPU driver is installed correctly.
I am looking for a solution to get the GUI screen working on Rocky Linux.
Update: I was successful in using the 550 (rather than latest 650) driver stream with Rocky Linux 9.4.
sudo dnf module install nvidia-driver:550-dkms
Thanks! i solved this issue with previous version of the driver as you said.
