I would like to write a C/C++ GUI for my .cu program. I will draw a tree base on the data generated from .cu program. Buttons, textarea, image plane may be included. Any idea of how to do it?
Thanks!!
Or has anyone had have a chance to try using Java/JNI to write user interface, then call cuda routines?
eirik
May 18, 2008, 4:39pm
2
Thanks!!
[snapback]378926[/snapback]
Take a look at Trolltech’s Qt. It should have what you need.
Qt is probably the best choice, but if the license doesn’t fit you, you may try wxwidgets.
[snapback]380330[/snapback]
Thirded. Qt is a pleasure to program and use, if only for the elegance of implementation.
I am actually using JNI to do it. Cause I think it may be easier to make graphics in Java.
[snapback]381192[/snapback]
Wish I knew more, but let us know if you find anything. Java and CUDA is dangerous but interesting waters.
wumpus
May 23, 2008, 10:16am
7
fltk (http://www.fltk.org/ ) is also nice, if you need a small, portable and simple user interface with good OpenGL interoperability.
