The page title is Tutorial - SAM (Segment Anything). The content is for TAM which is what I need.
But then when I run the following command as instructed on the page:
jetson-containers run $(autotag tam)
The command ends with launching Jupyter (port 8888, of course) and port 12212 is unreachable. How can I get the TAM UI launched through the jetson-containers? Which one, please? Thanks.
Regards.
P.S.
During the first attempt of the command listed on the page, a whole slew of packages was installed, but at the end Jupyter was launched. During the second attempt nothing was installed but Jupyter was launched.
There is no reference to any access via port 12212 but Jupyter is available via its standard port; unexpected since (unrelated, of course) I was expecting output along the lines of NanoOWL where I could access the web server remotely.
I ignored the page title because it is quite conceivably a typo. The page content is for TAM and that is what I intended to step through. Thanks.
Just want to double-check which container you use and is your environment JetPack 6.2?
We tried to build a SAM or TAM container on the latest r36.4.3 but it keeps failing due to unexpected dependencies.
Not an issue at all! Perfectly understand, and besides there are abundant official tutorials (across the entire Embedded spectrum) to keep me busy with other exercises on the Orin Nano. Besides, I lost several weeks of activity owing to relocation. Here is the information you requested:
