Hello experts,
We are currently planning to develop and demonstrate a multi-sensor fusion application using the NVIDIA Jetson Orin NX, running JetPack 7.2.1.
Our planned hardware configuration consists of:
6 × GMSL cameras
1 × Ouster OS1 LiDAR
1 × Radar (yet to be confirmed)
1 × IMU (ICM-42688-P)
1 × GNSS receiver providing NMEA and PPS outputs
NVIDIA Jetson Orin NX (Hardware PTP support enabled) as the central processing platform
Our intended architecture is to use the GNSS receiver as the absolute time reference and the Jetson Orin NX as the central processing and synchronization platform.
GNSS RECEIVER
(GPS / Global Navigation)
NMEA / UART 1 PPS
(UTC, Position) (Timing Reference)
v
| NVIDIA Jetson Orin NX|
| GNSS-disciplined |
| clock (intended) |
| PTP Grandmaster |
| (IEEE 1588, intended|
| where supported) |
| Sensor Fusion |
| DeepStream / DS3D |
v v v
| 6 x GMSL | | LiDAR + Radar | | IMU |
| Cameras | | | | |
| | | Ethernet/PoE | | I2C / SPI |
| | | PTP / IEEE1588 | | ICM-42688-P |
| GMSL -> CSI | | Ouster OS1 | | FSYNC / |
| | | Radar | | Timestamp |
| HW Trigger | | | | |
| 30 Hz | | 10/20 Hz | | |
v
| SENSOR FUSION |
| Timestamp alignment |
| Calibration |
| Coordinate transforms |
| Camera + LiDAR |
| + Radar + IMU |
v
| PERCEPTION / AI |
| 3D Object Detection |
| Object Tracking |
| Scene Understanding |
| Visualization |
2. Current implementation status
1. GNSS synchronization
We have synchronized the Jetson Orin NX with an external 1 PPS signal from a GNSS receiver by using chrony.
The GNSS receiver also provides NMEA data containing UTC time and positioning information.
Our objective is to maintain a GNSS-disciplined time reference on the Jetson.
2. Camera synchronization
We have configured hardware triggering for the camera using a Jetson platform GPIO/PWM signal.
The camera synchronization signal operates at 30 Hz.
We are capturing camera frames through the V4L2 interface.
3. Camera timestamp investigation
We have inspected the NVIDIA camera driver implementation, particularly:
public_sources/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/vi/vi5_fops.c -
We observed the following assignment:
vb->vb2_buf.timestamp = descr->status.sof_timestamp; -
We understand that the current V4L2 frame timestamp is based on the platform’s hardware timestamp/counter mechanism (TSC).
3. Areas where we need NVIDIA’s guidance
Question 1: Obtaining UTC timestamps for camera frames through V4L2
We currently receive camera frame timestamps through the V4L2 buffer interface.
As mentioned above, the NVIDIA camera driver assigns the SOF timestamp using:
Our requirement is to associate every captured camera frame with an accurate UTC timestamp referenced to the GNSS-disciplined clock.
We would like to understand:
Is there an NVIDIA-supported mechanism to obtain the UTC equivalent of the camera SOF timestamp?
Is it possible and recommended to modify the V4L2 driver so that the buffer timestamp directly represents UTC time instead of the existing timestamp clock domain?
If directly replacing the V4L2 timestamp is not recommended, what is the correct approach to preserve the original SOF timestamp and provide its corresponding UTC timestamp to GStreamer and DeepStream?
Question 2: Synchronizing LiDAR , camera and IMU data with different operating frequencies
We are planning to use an Ouster OS1 LiDAR connected over Ethernet.
Our understanding is that the LiDAR can synchronize its clock using IEEE 1588 PTP, with the Jetson acting as the PTP Grandmaster, provided the network interface and PTP configuration support this arrangement.
The expected operating frequencies are:
Camera: 30 FPS
LiDAR: 10 Hz or 20 Hz
IMU : 100Hz
In this scenario, the camera, LiDAR and IMU will not produce data at the same frequency.
What is the recommended method to associate camera frames with LiDAR measurements using timestamps?
Should we use the LiDAR scan timestamp, individual point/column timestamps, or another timestamp reference?
How should we handle the fact that a LiDAR scan is acquired progressively while the camera captures a frame at a particular exposure interval?
Does DeepStream DS3D provide any built-in timestamp-based synchronization or temporal association mechanism for this use case?
What is the recommended approach for motion compensation when the camera and LiDAR measurements are acquired at different times?
Question 3: Validating synchronization accuracy
We would also like to validate the synchronization accuracy across all connected sensors.
What tools, NVIDIA APIs, or recommended procedures are available to measure:
GNSS PPS to Jetson clock offset
Jetson clock to Ethernet PTP device clock offset
Camera hardware SOF timestamp accuracy against UTC
LiDAR PTP synchronization accuracy
IMU timestamp accuracy and synchronization with the Jetson
Long-term clock drift between the sensors
Are there any recommended NVIDIA tools or example applications for performing these measurements on Jetson Orin NX?
Question 4: Using NVIDIA DeepStream for sensor fusion
We are planning to use NVIDIA DeepStream and its 3D sensor fusion capabilities for our demonstration.
We have been exploring the following examples:
A. BEVFusion
We found the DeepStream BEVFusion example for multi-camera and LiDAR fusion.
However, our understanding is that the documented workflow involves a separate x86-based machine/server for some of the inference components.
Since we have only the Jetson Orin NX platform available, could you clarify whether this example can be adapted to run completely locally on the Orin NX? If so, what components would need to be modified or replaced?
B. V2XFusion
We also found the DeepStream V2XFusion example.
Could you provide guidance on whether this example can be adapted for our configuration of 6 cameras and 1 LiDAR, running locally on Jetson Orin NX?
In particular:
Is this example suitable for demonstrating camera-LiDAR sensor fusion?
Can it be adapted to our camera and LiDAR configuration?
Does it support timestamp-based synchronization of incoming sensor data, or would we need to implement temporal association separately?
Can the required inference components run locally on the Orin NX without an external x86 GPU server?
C. Radar and IMU integration
In addition to cameras and LiDAR, we intend to integrate radar and IMU data.
What is the recommended way to introduce radar detections and IMU measurements into the DeepStream/DS3D pipeline?
Would you recommend implementing a custom fusion component for radar and using a separate localization/state-estimation component for IMU and GNSS?
4. Objective of the initial demonstration
At this stage, our primary objective is to demonstrate a working multi-sensor fusion application on the Jetson Orin NX.
We would initially like to demonstrate:
Camera-LiDAR fusion
3D object detection and tracking
Radar-assisted object detection/tracking, if feasible
Timestamp-based association of measurements from different sensors
Visualization of the fused results
We would prefer to use NVIDIA DeepStream/DS3D wherever possible rather than develop the entire perception pipeline from scratch.
We would appreciate guidance from NVIDIA engineers and the developer community on the recommended synchronization architecture, timestamp handling, and DeepStream implementation approach for this hardware configuration.
