Hi, I have tested docker 4.0 with win11, it works.
But I can’t use any cuda image from hub.
I have tried:
docker run --gpus all -it --rm nvcr.io/nvidia/pytorch:21.08-py3 bash
docker run --gpus all -it --rm nvidia/cuda:11.4.1-devel-ubuntu18.04 bash
docker run --gpus all -it --rm nvidia/cuda:10.2-devel-ubuntu18.04 bash
All of these can’t run nvidia-smi.
And there are some error messages shown in the container by nvcr.io/nvidia/pytorch:21.08-py3:
WARNING: The NVIDIA Driver was not detected. GPU functionality will not be available.
Use 'nvidia-docker run' to start this container; see
https://github.com/NVIDIA/nvidia-docker/wiki/nvidia-docker .
NOTE: MOFED driver for multi-node communication was not detected.
Multi-node communication performance may be reduced.
NOTE: The SHMEM allocation limit is set to the default of 64MB. This may be
insufficient for PyTorch. NVIDIA recommends the use of the following flags:
nvidia-docker run --ipc=host ...
Which deep learning images can be used?
Hello, everyone. For the question nvidia-smi can’t use in nvcr.io/nvidia/pytorch:21.08-py3 , there maybe some bug in docker for windows.
I have tried the method in CUDA on WSL :: CUDA Toolkit Documentation (nvidia.com) to install nvidia-docker in wsl2. It works.
When you use nvidia-docker, attention:
When running the NGC Deep Learning (DL) Framework GPU containers in WSL 2, you may encounter a message:
Note that this message is an incorrect warning for WSL 2 and will be fixed in future releases of the DL Framework containers to correctly detect the NVIDIA GPUs. The DL Framework containers will still continue to be accelerated using CUDA on WSL 2.
I installed docker-desktop4.24.06 in Windows 10 19042.928. The graphics card driver is 537.42 and the following error is reported. How should I solve it?
The image has been installed without any problems
docker run --gpu all
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as ‘legacy’
nvidia-container-cli: initialization error: load library failed: libnvidia-ml.so.1: cannot open shared object file: no such file or directory: unknown.
opened 03:25AM - 09 Dec 23 UTC
needs-triage
### Description
I installed docker-desktop4.24.06 in Windows 10 19042.928. The … graphics card driver is 537.42 and the following error is reported. How should I solve it?
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'legacy'
### Reproduce
### Expected behavior
_No response_
### docker version
```bash
C:\Windows\system32>docker info
Client:
Version: 24.0.6
Context: default
Debug Mode: false
Plugins:
buildx: Docker Buildx (Docker Inc.)
Version: v0.11.2-desktop.4
Path: C:\Program Files\Docker\cli-plugins\docker-buildx.exe
compose: Docker Compose (Docker Inc.)
Version: v2.21.0-desktop.1
Path: C:\Program Files\Docker\cli-plugins\docker-compose.exe
dev: Docker Dev Environments (Docker Inc.)
Version: v0.1.0
Path: C:\Program Files\Docker\cli-plugins\docker-dev.exe
extension: Manages Docker extensions (Docker Inc.)
Version: v0.2.20
Path: C:\Program Files\Docker\cli-plugins\docker-extension.exe
init: Creates Docker-related starter files for your project (Docker Inc.)
Version: v0.1.0-beta.7
Path: C:\Program Files\Docker\cli-plugins\docker-init.exe
sbom: View the packaged-based Software Bill Of Materials (SBOM) for an image (Anchore Inc.)
Version: 0.6.0
Path: C:\Program Files\Docker\cli-plugins\docker-sbom.exe
scan: Docker Scan (Docker Inc.)
Version: v0.26.0
Path: C:\Program Files\Docker\cli-plugins\docker-scan.exe
scout: Command line tool for Docker Scout (Docker Inc.)
Version: 0.24.1
Path: C:\Program Files\Docker\cli-plugins\docker-scout.exe
Server:
Containers: 1
Running: 1
Paused: 0
Stopped: 0
Images: 1
Server Version: 24.0.6
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Using metacopy: false
Native Overlay Diff: true
userxattr: false
Logging Driver: json-file
Cgroup Driver: cgroupfs
Cgroup Version: 1
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
Swarm: inactive
Runtimes: io.containerd.runc.v2 runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 8165feabfdfe38c65b599c4993d227328c231fca
runc version: v1.1.8-0-g82f18fe
init version: de40ad0
Security Options:
seccomp
Profile: unconfined
Kernel Version: 5.10.16.3-microsoft-standard-WSL2
Operating System: Docker Desktop
OSType: linux
Architecture: x86_64
CPUs: 20
Total Memory: 12.28GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
HTTP Proxy: http.docker.internal:3128
HTTPS Proxy: http.docker.internal:3128
No Proxy: hubproxy.docker.internal
Experimental: false
Insecure Registries:
hubproxy.docker.internal:5555
127.0.0.0/8
Live Restore Enabled: false
WARNING: No blkio throttle.read_bps_device support
WARNING: No blkio throttle.write_bps_device support
WARNING: No blkio throttle.read_iops_device support
WARNING: No blkio throttle.write_iops_device support
WARNING: daemon is not using the default seccomp profile
### docker info
```bash
Client:
Version: 24.0.6
Context: default
Debug Mode: false
Plugins:
Version: v0.1.0
Version: v0.2.20
Version: 0.6.0
Version: v0.26.0
Version: 0.24.1
Server:
Containers: 1
Running: 1
Paused: 0
Stopped: 0
Images: 1
userxattr: false
Cgroup Version: 1
Plugins:
Volume: local
Swarm: inactive
Security Options:
seccomp
Profile: unconfined
OSType: linux
CPUs: 20
Debug Mode: false
Experimental: false
127.0.0.0/8
### Diagnostics ID
无法生成
### Additional Info
_No response_
