Guys Pls help me (CUDA problem) CUDA is not detecting by my PC
My Graphics card is Nvidia GeForce 430GT 1GB DDR3
my motherboard is ASUS M5A78L-MLE and Pro. is AMD Athlon II X3 445 (3.1Ghz)
When i installed Badaboom it says ur GPU is not supported by CUDA. But my GPU is CUDA enabled and i used it one my Old PC(MB was Asus M2N-MX-SE plus and pro. AMD Athlon II X2(2.2Ghz). I tried it on win 7 but nothing happend (Still the Error) then i tried Win XP but pblm exist! i got a better version than the CD that comes with the Package. What is this?
Is this the END of my GPU?
I gave 100$ and bought it mainly for Faster Convertion.
PLS HELP ME GUYS PLS
Thanks in Advance
I WANT SOLUTION !!!
This is the Log showing the version PLs check:
Display Devices
    Card name: NVIDIA GeForce GT 430
 Manufacturer: NVIDIA
    Chip type: GeForce GT 430
     DAC type: Integrated RAMDAC
   Device Key: Enum\PCI\VEN_10DE&DEV_0DE1&SUBSYS_00000000&REV_A1
Display Memory: 1024.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0012.6658 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 1/8/2011 08:57:00, 6397824 bytes
WHQL Logo’d: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 1/8/2011 08:57:00, 9888672 bytes
Device Identifier: {D7B71E3E-4EA1-11CF-B279-0C2000C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0DE1
SubSys ID: 0x00000000
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: The tests were cancelled before completing.
D3D8 Test Result: The tests were cancelled before completing.
D3D9 Test Result: The tests were cancelled before completing.
Could you briefly explain how did you install cuda? I think the cuda toolkit has to be install properly in order to use gpu for other things.
How is that?
I simply installed Nvidia Drivers that i donwlaoded from Nvidia driver Downloads!
can u provide the links PLs?
What exactly did you install? Did you install the CUDA toolkit from here http://developer.nvidia.com/cuda-toolkit-40 ?
No i just installed Nvidia Driver which i got when i purchased my CARD!!!
Install the latest nvidia driver and then the cuda toolkit,optionally you can install also the examples. This is the only way it will work.
