Error] [carb.gym.plugin] Function GymGetActorDofStates cannot be used with the GPU pipeline after simulation starts. Please use the tensor API if possible. See docs/programming/tensors.html for more info.
I am getting this error after starting training
Hi, I am getting this same error with training, found a way around it?
@kellyg , @gstate, anything you could say about this? Thank you!
The error you get stems from the fact that you are trying to call (directly or indirectly) a method (get_actor_dof_states
) which is not compatible with the GPU pipeline. If you set the argument use_gpu_pipeline to false, the error should disappear. If you cannot avoid the use of the GPU pipeline, then you should look at the acquire_dof_state_tensor
method from the TensorAPI. You can find the documentation of the API by opening the isaacgym/docs/api/python/gym_py.html
document.
I got the totally same error as both of U. I was trying to nest two RL algorithms, running a new RL process inside the reward function of the RL algorithm in the outer loop, so I reported this error in the RL in the inner loop. Have you guys solved this error? And how?
