H.265.ts playback issue
We observed one H.265.ts playback issue in R24.2 image on TX1 EVK. The video would be faster than normal playback for four times when we used below command to do playback. And it happened every time. Furthermore, we found that the fps was showed 120 fps. You can also refer to my attached video in cloud disk. Can you kindly help to check this issue ? If you have any questions, please feel free to contact me.
Command : “gst-launch-1.0 uridecodebin uri=file:///CppSourceFiles/record11.ts ! nvoverlaysink”
Video : https://www.dropbox.com/s/h908nrj3d7tl302/record11.ts?dl=0
I also attached the log file of this issue for your reference. If you have any questions, please feel free to contact me.
H265.ts playback issue.txt (2.24 KB)
Hi James,
We can observe the issue on r24.2.1 and are checking further.
Hi James,
The video file does not have correct timestamps. Please download and try the remux-ed one:
Username: NFOWSMSCQE
Password: -B5i=HLv
Download URL:
https://ftpservices.nvidia.com
The login above will expire on 1/24/2017 12:00:00 AM
It is remux-ed via ffmpeg
./ffmpeg -i record11.ts -c copy -r 30 record11_r.ts
Hi James_Liang,
Has this issue been clarified and fixed?
Or still need the support to move forward?
Hi Kay,
Thanks for your full support. About this issue, we have solved it.
